Author Topic: Toyota Transfer Cases  (Read 2223 times)
tboss
  • Member since Feb '04
« on: Feb 02, 2004, 02:05:28 PM »
I seem to have a problem with Toyota transfer cases breaking in half. The last one even had a case saver on it I picked up from Over The Hill 4X4 a while back. I'm running a 350 and NV4500 in my 76 FJ40 and 35'' tires, locked front and rear. I would welcome any suggestions.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re:Toyota Transfer Cases
« Reply #1 on: Feb 02, 2004, 11:32:02 PM »
The newer t-case is always the strongest, with the 78-80 being the best 1" center pin t-case. Toyota also made a 34 mm center pin one peice case for South America, however, that is also obsolete. :(
Danny Warden made a bilite aluminun case ($1349.00), He is no longer in business.
I looked into making a billite case, but, with my new manager, we have gotten very busy and I have not had the time to finish the project!
AA is planning to sell a cast iron case with a 4 to 1 gear set for some time now.
Make sure that there is at least a 5 inch lb preload on the output shaft. I fell that a loose output shaft only helps break cases :help:
Marlin
84runner
  • Turtle Points: 99
  • Member since Dec '02
« Reply #2 on: Feb 06, 2004, 12:34:36 PM »
tboss you got any pics of that t-case?
Last post Dec 31, 2006, 08:04:20 PM
by teamfx3
Last post Sep 23, 2019, 07:06:15 AM
by RawkPunx4x4
Last post Jul 23, 2009, 11:09:53 PM
by Doof
Last post Dec 29, 2010, 10:06:07 PM
by dntsdad
Last post Oct 06, 2011, 11:24:55 AM
by blackdiamond
