XJ IDEAS FOR LITTLE SKITTLES
Started by LITTLE SKITTLES, October 24, 2006, 05:02:38 PM
boggerunner
i like the windshield tape job on the black xj, must be a jeep thing, im guessing thats plexiglass too?
iNfErNaL
Quote from: boggerunner on October 24, 2006, 09:58:57 PM
Nonesense poopie pants...He had just rolled it about an hour before I took the picture and the windshield had shattered.He had to drive it home so he popped his back window out and duct taped it to the front.Oh,and his girl was a few months pregnant back then.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
iNfErNaL
Quote from: kneedownnate on October 24, 2006, 09:54:55 PM
you're talkin cj if you're thinkin a 231 came stock.
Sorry bud,CJs did not come with 231s.
iNfErNaL
Ruggedjeep
Very easy to keep it simple, especially for a novice. Get a 2" BB with shocks from Rubicon Express for under $200, that includes shocks(im sure the stock ones need to be changed) Trim the fenders and you will clear 31's. With that height chances are you wont need a SYE, but every XJ is different so no promises. TC is either a NP231 or a NP242 both decent cases but the 231 is better and a little stronger with more aftermarket support. A low range in the TC, tera sells a 4.1 that goes for $700 if your lucky. Get some rock rails for it and some other armor and you should be good to go. Rear axle is either a D35 or a 27spline 8.25, both c-cliped and weak. Look for a D44 for a XJ they came in 87-89 easy bolt on upgrade and could be had for around $250 or so from the bone yard.
Goodluck, if you have any more questions shoot...
97 XJ 4.0 d30/c8.25 4.56/Detroit RE 4.5" 35's Caged and alot of Armor
www.RuggedJeep.com
http://ruggedjeepadventures.fototime.com/welcome
iNfErNaL
Ruggedjeep
Quote from: Infernal on October 24, 2006, 10:39:23 PM
Or you could just listen to Ruggedjeep.If anyone knows XJs,it's this guy.
Thanks Infernal..  :thumbs:
oldyellercj: Lookin at the pic of the TC shifter, ill tell you, you've got a NP231. Advantage if you end up needing a SYE, you can get a hack N Tap from RE for about $90 and get a stock front driveshaft for an XJ and u have yourself a doube CV shaft.
www.RuggedJeep.com
iNfErNaL
Here's some inspiration for ya  http://www.pirate4x4.com/forum/showthread.php?t=50204&highlight=XJs  Lots of sweet XJs there.Also check out  www.naxja.com
iNfErNaL
Ruggedjeep
Yup, NAXJA is prolly your best bet. Endless info...
www.RuggedJeep.com
#40
Quote from: Infernal on October 24, 2006, 10:11:25 PM
Where would I verify this?  I've been told for years that some cj5s came with an oddfire buick v6, beit a 225, 231 or 4.1(242?), and have driven a supposedly stock cj with an oddfire.  I'ma hafta do some checkin on that one...
iNfErNaL
My bad.I thought you were talking about 231 T-Cases.
motorider228
I'm at work so I have no pictures of my first car here but I will post some when I get home. It was a 1986 XJ with the stock axles, stock 4 banger that I put a cold air intake on and an accel ignition. It was SLLLOOOOWWWWW. 10 inch skyjacker long arm lift which actually did me well. axles were the stock dana 30's with a spool in the rear and an arb up front both had 4.55's from yukon. I had 35 inch procomp xterrains and for the transfer case it had the tera 4:1 gears. I sold her for $650 because of rock rash. Also had a CB, roof rack and 4 KC lights. Plus I put a boat air horn on it....loud sucker haha. My point of posting all this is those stock axles should work fine for her while she is learning to wheel and don't worry about her going too fast in an XJ like that haha. Someday I will build one up again with a 4.0 High output 60's and coil overs with an internal cage.
Duffil
Quote from: oldyellercj on October 24, 2006, 09:18:52 PM
How do I know if its an ax5 :dunno: and where do I get one of these G52 things from
I gots one.  :cheese:
*** YELLER ***
Quote from: motorider228 on October 25, 2006, 02:20:55 PM
where those pics at ???
except BACON
*** YELLER ***
except BACON
Ruggedjeep
www.RuggedJeep.com
Ruggedjeep
For what its worth, i would never run 35's on that setup. D30-D35 is not a setup for 35's especially a welded 35. Suprised you didnt gernade that thing. To run 35's on a D30 i would highly suggest alloys, and atleast a D44 or a 8.8 outback..
www.RuggedJeep.com
*** YELLER ***
Quote from: Ruggedjeep on October 25, 2006, 06:12:15 PM
Here is some pics of my Junk
I can only hope our "junk" is as capable as that
except BACON
motorider228
Only pictures I have as the rest were deleted from my hard drive. I am also surprised my rear end didn't blow up. I would have swapped 60's into it if I kept it though. (these are on my old property so no one jump on me for killing trees) and yes I know they are poser shots haha
Blingn
oldyellercj pm sent!  hope it helps!
Duffil
Quote from: oldyellercj on October 25, 2006, 05:20:45 PM
you gots one do :think: you then maybe we need to talk :thumbs:
:usa: :beerchug:
lemme know what you decide.  I'm sure it'll still be here.
MiniSimp
 :idea: Drop off XJ at Dave's Offroad, give Dave check, pick up finished XJ. :gap:
iNfErNaL
Quote from: MiniSimp on October 25, 2006, 10:14:57 PM
You know Dave?.He's a cool cat.
Duffil
MiniSimp
Quote from: Infernal on October 25, 2006, 10:21:46 PM
We've met.
Seriously though Dave, just go over to Daves after the motor swap and drop that thing off. I'm sure he would have some Ideas about the budget end of it. Hell, for now lets just wheel it. I wanna see what Jessica can do! :greengrin: :driving:
crashtestdummie
Quote from: 79Coyotefrg on October 24, 2006, 06:09:23 PM
its a V 6  :headscratch:                 never saw a modern jeep with a v6  :dunno:
yes my cherokee had the 2.8   :reg: chevy  v6 came stock in 84 and opt in few fallowing years till they relized it was junk . but I liked mine and like any GM motor they are easy to up grade and get more power or torque  out of them  :driving: mine drove great (when it ran)
get in, sit down, buckle up, hang-on, and watch your head
FFC will always have alittle part of me with her. I never did find that tooth I broke. :rotfl:
*** YELLER ***
yea tell that to Julie and we will go for it....
except BACON
*** YELLER ***
Quote from: MiniSimp on October 26, 2006, 06:06:19 AM
We've met.
Seriously  :mad: STOP SPENDING  :slap: my money Jessie is doing  just fine with that.  :smack:
PMed Blingin and he has some parts and ideas so we will see...
except BACON
