my new toy and project hope to be back up and running by nov 15
Started by rickibrat2, October 20, 2006, 07:36:20 AM
rickibrat2
basicly yes the wheels are for sale the cab is for sale the exo cage is for sale
i have on order F toy # 58
it will better suit my needs o 2 seats plus a jump seat in the rear and it is more rail like'
have no interest in going streetlike some one said it just makes more sense to go this way
so will restart the thread when the new body gets here
right now still workoing on the chassie rebuild the front end to day hope to hang it in the am so i will be back to a rolling chassy ring and pinions should be done this weekend and built with all new parts and 5.29 gearing spool in the rear and easy locker moved to the front alxe
have drag link for sale lift kit for sale and old lift kits goes with the body if some one buys it if not it goes to junk yeard too
olivedrab85
How you liking the nice Oregon rain? Are you still working on this in the driveway?
"Gotta keep it G rated for Marlin"   my runner http://board.marlincrawler.com/index.php?topic=26527.0
Reynolds
Quote from: gotrocks on October 31, 2006, 09:53:34 AM
nooooo, build a cab with the exo.  I really don't understand the whole f-toy thing.  If you are going to go that far just build a real buggy
Formula Toys, in my opinion are a cheaper, easier solution than building a buggy. It basically is a truck with tube instead of a cab but that route works just fine. Not to mention it takes all the guess-work out of building a buggy too. I think they are a great solution :) To each their own though...
-Brian
rickibrat2
have to love the rain ye it is still in drive way
chad and his brother are suppose to do the rear ends this weekend so they can come inside after that front axle rebuilt the renforcement has been done to them
and on new springs just waiting for a few hours of no rain to go back on truck
same with the rear end the housing is all done rady to go back under truck
now waiting for new motor mounts to get here and the new spring hanger to move the rear inboard
dui distribter should be here this week, fuel injection should be here this week
and new alternator rated at 130 amps one wire type
hope to get new clutch in this coming week and to hang the new crawler box then rebuild the transfer case to 4.70 gearing
and mount it them check size and order drive lines
ram steel has my metal in for fire wall and flooring
so it will be here when toy body gets here then will take to wild wet welding for them to mount it to frame and rough in fire wall and flooring
will be  using AFCO TILTON MASTER CYLINDER CLUTCH PEDALS STOCK CAR   which has 2 brake cycynder so i can adjust front to rear breaking pressure
looking at using a nascar pump to drive power steering and hydro assist as i t has 2xs the line pressure of a stock pump and 2xs the flow
gonepostal
nice truck, apparently they don't salt the roads in Oregon.  Lucky to find one that nice, can't do that in Michigan. :beer:
gotrocks
so I guess your not going to have it done by the 15th now since your going Ftoy
rickibrat2
nope going to take my king quad to play with
it only has a 3 inch lift and running 28 inch tires and chipped
TrackVino
