Author Topic: Removing IFS box  (Read 2408 times)
scarboy
  • Member since Feb '06
Removing IFS box
« on: Oct 15, 2006, 02:38:34 PM »
What all do I need to do to remove the pitman arm from the steering.....not the box end but what the other side connects to.
Plowking
  • Turtle Points: -75
  • Male Posts: 504
  • Member since Jan '05
  • Awesome yota
    • Buy me a drink
Re: Removing IFS box
« Reply #1 on: Oct 15, 2006, 03:02:21 PM »
Impact gun definantly need the pop of a good impact gun.
The puller running or being opperated with impact gun is a must.
2008 Dodge Diesel  (Cummins Rule)
6.7 manual quad 8 foot bed H&S delete, banks air box
93 yota 3.0 locked up...
2004 Yamaha Raptor 660R
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
« Reply #2 on: Oct 15, 2006, 03:15:44 PM »
possibly a torch, heat it up a little to expand the metal if its a pita.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #3 on: Oct 15, 2006, 03:18:26 PM »
it was my understanding he wants to get the draglink off the pitman,  if this is the case you need a tie rod fork and BFH
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #4 on: Oct 15, 2006, 03:26:07 PM »
i have always liked the little pitman arm puller tools, they press it off and dont trash the boots on anything, they can also be used on tie rod ends, and balljoints
Plowking
  • Male Posts: 504
  • Awesome yota
    • Buy me a drink
« Reply #5 on: Oct 15, 2006, 03:35:52 PM »
The fork will work my bad. If you were gonna get that arm off the steering box you would need the impact gun.
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #6 on: Oct 15, 2006, 04:26:19 PM »
pitman arm puller+heat
crank down the puller and heat the pitman arm up at the splines *POP*!!!
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
« Reply #7 on: Oct 15, 2006, 05:56:16 PM »
Some of yall need a lesson in reading comprehention, (spell?) and I need to learn to spell. :dunno: A hammer a wrench and pliers   Pliers to remove the cotter pin a wrench to remove the nut and a hammer to wack the pitman arm till the end pops off.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
« Reply #8 on: Oct 15, 2006, 06:07:26 PM »
Why are you coming on here and telling people when you can't spell the word comprehension.
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
« Reply #9 on: Oct 15, 2006, 06:47:22 PM »
yea you can spell yea :bowdown:your right that was unneeded but at least i tried to help did you?
my favorite places:
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
« Reply #10 on: Oct 16, 2006, 12:31:53 PM »
A pickle fork and hammer.  If you are going to hit the draglink end, leave the nut on because otherwise you will screw up the threads and you will have to buy a new one.  Also, you might heat it up with a torch.
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
« Reply #11 on: Oct 16, 2006, 01:37:04 PM »
An air operated pickle fork. Used one this weekend, did rip a boot.
Time to go wheelin!
BCD
  • Turtle Points: -79
  • Male Posts: 70
  • Member since Dec '04
« Reply #12 on: Oct 16, 2006, 05:00:33 PM »
I use a pitman arm puller, apply tension and lightly tap the puller on both sides, then apply more pressure, tap both sides, and it pops off pretty easily.
-Brian
Saber
  • Turtle Points: 3
  • Male Posts: 50
  • Member since Apr '06
  • What up "G"
« Reply #13 on: Oct 17, 2006, 11:47:20 AM »
If you don't plan to reuse the pitman arm, just dissect it from the steering box.  When I did my SAS, my pitman arm would not budge no matter what.  Spent way too long trying to gracefully remove it, using every method known to man.  Decided to use my grinder with a cutoff blade instead.  I cut an X on it and hit it with a BFH.  Took about a minute of my time and it popped right off.  Just be sure you don't cut too deep and damage the splines on the steering shaft.
 :thumbs:
***  SAS'ed '94 ext. cab - V6 auto - 4.88's - TrueTrac front & rear  ***
Saber
  • Turtle Points: 3
  • Male Posts: 50
  • What up "G"
« Reply #14 on: Oct 17, 2006, 11:52:43 AM »
Oops...  Just read the original post.   :hammerhead:
Use a pickle fork and an air hammer, just as the other gents stated...
 :gap:
Last post Jan 31, 2008, 06:21:51 PM
by motoracer
Last post Apr 28, 2008, 08:57:12 PM
by BLACKDOG
Last post Sep 21, 2009, 10:35:45 PM
by 88_Pathy
Last post Feb 02, 2010, 05:38:01 PM
by Toyotero
Last post Dec 30, 2009, 07:40:12 PM
by DFWFO
