20r head on 22r motor
Started by yota_krawler, October 13, 2006, 01:02:58 PM
yota_krawler
has anyone done a 20r head on a 22r motor and if so does it do anything for you? I had someone tell me that it give more power and compression. I was just wondering.
TRHS1980
There's tons of info on the mod if you look around the board. Here's a link that might help...
http://board.marlincrawler.com/index.php/topic,27651.0.html
What I can personally tell you is that the 20R head has a hemispherical combustion chamber (it's a hemi) so it flows real nice making usable power up to 6000 RPM. It also has a smaller combustion chamber meaning it'll up the compression a bit. You're going to lose a bit of low end torque, but for a daily driver it's nice to have the stronger top end. Throw some O/S valves in there and a mild came and your well on your way to an R series motor that can actually get out of it's own way. If you ever plan on going EFI then this mod is not for you, since the FI intake won't bolt onto a 20R head. Also, I wouldn't use the stock 20R carb. Go with at the minimum a 22R carb, or better yet, a weber 32/36.
2007 Tacoma 4x4 6-speed on 35's
"In all affairs it's a healthy thing now and then to hang a question mark on the things you have long taken for granted."
Our search function doesn't work very well usually, but if you just look at the thread titles and check the ones that look like they may cover it you'll find TONS of threads on this.  You can also check this thread for some good info on hybrids, http://board.marlincrawler.com/index.php/topic,5628.0.html
With only a stock 20r head on a stock 22r bottom you won't gain too much.  Warm up the head a little though and it'll give good gains.  It's really a matter of how much you wanna dump into it.
I can personally tell you that going from stock 22r to slapping on a stock 20r head made my engine more usable and stronger everywhere.  I'm currently replacing a headgasket and will be dropping in a slightly bigger cam, but will be building another hybrid with big valves and port work in the near future.
4inchToyotas
Plenty of people here have done this. Just make sure you're using the "early" block and you'll save some time and effort. If you have any specific questions go ahead and ask. We need to get a 20/22r FAQ/writeup going, so maybe this could help others too.
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
sof'indetermined
83 yota that wheels
04 wrx wagon that hauls butt
assorted crap that mostly doesnt do anything
4inchToyotas
Anyone got any pictures of when they did theirs? I know it's not difficult to explain. Just that some people may want to see the deiiferences.
take everything from a 20R  and put it on the 22R block :thumbs:
well,  almost   use the 22R rockers,  and 22R exhaust  if you dont have the :bling: for a header
4inchToyotas
I'll try to search for the pictures...hopefully to get fewer inquiries into this.
i didnt have a digi  when i did mine  :down:
4inchToyotas
yeah..and mine was built for me. I was just thinking of showing the different piston tops etc. obviously the head desgin (intake)
