BUILT '88 Sammi near Sac. Ca.
Started by rockcrawlinredneck, October 06, 2006, 10:02:00 PM
rockcrawlinredneck
I am posting this for a buddy of mine, this is a very nice rig. It is the first Sammi I had ever wheeled and I was impresed to say the least. Any how here are the spec's.
'88 Suzuki Samurai ready for the trails. Has been on only 2 trail rides.
Burgandy in color
1.3 ltr, new t-belt water pump, drive belt, valve cover gst, front engine seals
cap,rotor, plugs (motor runs strong, no smoke or knock)
Red top Optima battery
"clicky starter fix relay"
KC highlights
Toyota celica P/S RRO install kit with good size p/s cooler
Trail Tough cross over samurai to toyota steering
Ford shock towers (reinforced frame mounts)
Doestch Tech shocks (with bump stops on shafts)
Trail Tough missing links front and rear
Brand new R/E YJ springs
Toyota axles front and rear (front has factory truss, rear is the later model 2"wider than front)
4:88 gears (new timken bearings and install kits)
Lok-Rite in rear, open in front
4:1 Cal-mini gears in T-case
Toy driveshafts front and rear (both C.V. style with RAT adaptors @ t-case)
New shift sheet
Larger trans shifter bolt (less likely to break, cure for sloppy shifter)
High clearance trans mount (rock 4X)
Rear shock relocation mount to inboard upper shock mounts( spidertrax)
5 Dunlop mud rovers '33 12.50 15's (2 trail rides on tires,still have tits on tread)
Wagon wheels ( 4 crome spare black)
Custom rocker rails
Front bumper 2x4 with D-rings
Trail Tough front interior roll cage
C.B.
AM/FM/CD
Brand new Best Top soft top. Windows in great shape
Brand new Bimini top Best Top
Grand Caravan 2nd row seats (with arm rests and built in cup holders)
Registered till March of '07
Smogged, may need cat conv
Speedo inop
Milage, 138973
Asking $5750.00 O.B.O.
need family type wheeler like XJ or 4runner comporable to this. Will concider trades
Call me @ 916-515-6282 or P.M. me Ask for Don
Located in Galt California (95632)
rockcrawlinredneck
Here are a couple of pic's.
(edit) the link's did not work, give me some time.
Shamb
re size them and just post directly here, you dont need a link
additional options, browse, attach.
nor-cal zukini
Sorry for not posting directly onto this forum, I am a newby here and my friend is a vet. here and computor illiterate.
I would have posted here but not able to. :jail:http://www.pirate4x4.com/forum/showthread.php?t=515623
nor-cal zukini
