T-case flanges??
Started by throttleboy, October 06, 2006, 05:29:46 AM
throttleboy
do'es someone make a flange that will except a 1410 J-joint at the T-case?? the D60 and 14 bolt i have both have 1410 yokes on them and i have one drive line with 1410 joints at both ends so i'd like to stay with the big joints if posable,thanks dave!!
KWP
 Nobody that I know of makes flages like that. You might try high angle driveline :dunno:. I know they make flanges for D60's to a toy driveshaft.
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
Shamb
all you have to do is find a driveline for a D60 or 14 bolt and cut the end off, take it to a local driveline shop and they'll mate it for you. Or look up TravelMaster drivelines.. or as KWP said High Angle will do custom work.
late 60's  F600's  had  a flange like a toyota,  but  a large  u joint
:thumbs:
