Reply #1 on: Sep 25, 2006, 11:27:02 PM »
Cold 35-40 lbs, hot 30-35.
Most efi pump will puh up to 80 + lbs with out the regulator
![](https://board.marlincrawler.com/Themes/MCI_V3C/images/ip.gif)
Logged
