Author Topic: Driveshaft rubbing on Ultimate Crawler  (Read 2377 times)
mt_goat
  • Member since Dec '05
« on: Sep 23, 2006, 07:55:32 AM »
Got the front driveshaft retubed (8 1/2 " longer because of the dual cases):
After getting it all bolted back on I see there is a problem, the driveshaft double cardan joint is rubbing the Marlin dual case adapter. So back off it came and I had to grind off some of the corner of the Marlin adapter:
I only have about 3/16" clearance between the two now, hope that's enough. I had tried to contact Marlin Crawler about what to do, but they are not answering their phones again, (they had a member of the tech staff die recently, rest in peace Dean-o)  Do people not normally use a double cardan joint with Marlin Crawlers or something?  This is on a 93 ext-cab with IFS and 5" suspension lift.   It's behind a 5VZFE motor and auto trans.
Dale
"America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war."  T. Boone Pickens
 Check out the plan: http://www.pickensplan.com/ and http://www.cngnow.com/EN-US/Pages/default.aspx
Re: Driveshaft rubbing on Ultimate Crawler
« Reply #1 on: Sep 23, 2006, 08:24:31 AM »
mine rubbed on the bench, but when it was connected to the 3rd  it did not,  remember its gonna be  pulled to the right and down,
and yes i had the double cardan joint  ,  still do
mt_goat [OP]
« Reply #2 on: Sep 23, 2006, 08:31:58 AM »
Do you have IFS too, or SA?
« Last Edit: Sep 23, 2006, 08:46:36 AM by mt_goat »
Dale
Willy Mammoth
  • Male Posts: 4,252
« Reply #3 on: Sep 23, 2006, 08:35:54 AM »
With the dual cases you may not need a CV in the front. Depends on the angle of the shaft and how much lift you have.
« Reply #4 on: Sep 23, 2006, 08:46:23 AM »
Do you have IFS too, or SA.
79,  ifs  wasnt even thought about back then
mt_goat [OP]
« Reply #5 on: Sep 23, 2006, 08:51:18 AM »
Oh yeah 79Coyote, I see now.  So yours only moves right and down huh?  Maybe IFS won't move at all?
Dale
toyman1994
  • Turtle Points: -32
  • Male Posts: 59
  • Member since Jul '05
  • I reject your reality and substitute my own...
    • Wheeling Arizona
« Reply #6 on: Sep 23, 2006, 09:32:27 AM »
ifs shouldn't move at all at the axle.  you will have a little bit of twist from the engine torque but not enough i believe you should be worried about.
RynsToy
SAS'd and Caged 94 PU on it's 4th set of tires in 6 months and hasn't moved an inch, currently, stock '65 GMC wheels.
RIP: Corporal Victor M. Langarica - 20 Jan 2007
CRS
  • Turtle Points: -22
  • Male Posts: 132
  • 1/4 TiLT
« Reply #7 on: Sep 23, 2006, 10:05:23 PM »
hell you dont even need a cv with ifs i have no idea why they ever put them on there.
IN LOVING MEMORY OF JAKE. MY BEST FRIEND AND COPILOT
                  WITH ME FOR A MILLION DAYS
                         2-15-05  4-12-06
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #8 on: Sep 23, 2006, 11:20:19 PM »
What in the world?
Has your drivetrain shifted to the passengers side, by, say, a foot?
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #9 on: Sep 24, 2006, 12:40:54 AM »
What in the world?
Do you have the Marlin crossmember?  Because it has slotted mounts, you may have bolted the crosmember off center.  :dunno:  check that out, you may find your problem right there.
Even if that isn't the case, with IFS you don't have any noticable movement of that driveshaft.  I'm running duals with my IFS, and it is close with my adapter as well, but not interfering.  I did have to clearance the crossmember a little, but not the adapter.
Check the centering of the drivetrain :thumbs:
              -Ronald Reagan
mt_goat [OP]
« Reply #10 on: Sep 24, 2006, 09:01:11 AM »
Ok you guys are kind of scaring me now.  :scared: :willynilly:  So I took some more pics to show how centered I am.
I've got the shifters coming up in the center of the console:
It's a Budbuilt crossmember but I made the mounts for it and I adjusted it so the shifters came up in the middle where I wanted them.  (please don't laugh at my very temporary exhaust rigging) :_oops:
Dale
« Reply #11 on: Sep 24, 2006, 09:23:48 AM »
i can see right there, the shaft  actually moves to the center, instead of  to the right or straight up  :screwy:
mt_goat [OP]
« Reply #12 on: Sep 24, 2006, 10:00:31 AM »
So is my IFS diff closer to the middle than a SA diff?   Will I be ok if I do a SAS later?  Will it be ok now with IFS and 3/16" clearance?   I just paid $100 to have the DS retubed and balanced so I'd kind of like to keep the CV joint.
Dale
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #13 on: Sep 24, 2006, 02:44:51 PM »
you should be just fine with the clearance you have. The minimal movement that there is shouldn't be an issue.  And from the pics, it does look pretty dang clse to center :thumbs:  if you've clearanced the case by 3/16" and aren't rubbing, you'll be fine.  Oh yeah, and you'll be fine when you do your SAS too, the IFS diff is closer to middle than the SA diff.
              -Ronald Reagan
mt_goat [OP]
« Reply #14 on: Sep 24, 2006, 04:57:51 PM »
Great thanks guys! :greengrin:
Dale
Last post Dec 07, 2004, 06:42:08 PM
by militarymudder
Last post Oct 05, 2005, 11:24:15 PM
by WHITE_TRASH
Last post Feb 28, 2008, 06:33:22 PM
by madmanweaver444
Last post Oct 19, 2011, 08:17:07 PM
by *** YELLER ***
Last post May 21, 2023, 09:59:06 PM
by Snowtoy
