Heavy Duty Shifter SeatIt's common for the factory shifter seat to wear, crumble and disintegrate over time. This often results in a sloppy or loose transmission shifter. The factory seat is soft so it can be squeezed into position. We took a different approach, and machined groves into the sides of our heavy duty seats. Instead of squeezing the seat into place, the groves on each side allow ours to rotate into position. This allows us to make our seat from stronger, longer lasting hardened urethane. Our new heavy duty seats will far out last the stock units and will reduce shifter slop. Please state year and model when ordering. Two different sizes, one sizes fits W56A and W56B models, the other fits all other 4wd applications as well as all Toyota Celicas and Supras. MC-10077, Heavy Duty Shifter Seat, All Other Toyota Applications, $10 MC-10078, Shifter Socket $6http://www.marlincrawler.com/htm/transmission/trans_parts.htm
Ernest, you can easily modify the L43 shifter to be alot tighterlook at my buildup i have pictures around page 10 but basically the shifter seat that is solid, unlike any other toyota tranny bolts to the tranny side, these bolts have rubber bushings in them that hold the shifter in place, i modified mine so these rubber bushings were replaced with solid metal inserts that i madei could easily make you a set or just look at the pics in my buildupyou canemail me from my profile if you need more info, btw are those texas tags?? i'm in Arkansas
there are bushing where the mounting bolts are,witch if gone will give a huge amount of slop.take $5 and go to the dealer and get new ones and be done with it
Started by aopharedrooster Rigs For Sale
Started by 80crawleryota Engine
Started by 80crawleryota « 1 2 » Parts For Sale
Started by Boerboel88 Toyota Pickup/4Runner Tech 1979-95
Started by D2therick Engine
