22re from a 85 pickup into a 92 pickup plug and play?
Started by D2therick, August 04, 2023, 06:19:45 AM
D2therick
will a 22re out of a 85 toyota pickup go in a 92 toyota pickup without changing the ecu of fuel injection parts?
sirdeuce
Not sure what you are asking, but the '85 block should drop right in with all the '92 external parts. There may be a difference in the motor mounts if you're going from a 2WD to a 4WD.
If you are asking about using the '85 EFI bits? Intake manifold and Throttle Body are different, Injectors are different, EGR is different, Air Injection is different. Yeah, it's best to plan to keep the '92 external engine parts.
Brought to you by the WBC (World Billionaire's Club) because money is a bad thing. Let us carry that burden for you.
Sure it'll fit........ Just needs a little brute finesse.
Sure I believe intelligent life exists on other planets. Other planets, not this one.
