Reply #1 on: Sep 14, 2006, 09:21:41 PM »
Connect the hose from the center of the intake mainafold to the rear of the drivers side stand pipe. This will complete the cirulation when the thermostat is closed.
The outer vacume line is the advance side of the distributor. It needs to go to the ported source on your carb when you open up the throttle. Do not use the inner retard diaphram.
Logged
