IFS box hoses
Started by stomper, February 25, 2005, 01:44:00 PM
stomper
Im going to do my crossover this weekend And had a ?. Im sure I read the stock hoses on my 85 will work. Right? Also wich one is the high side and low side?
Brandon
pretty sure they only go one way, should fit. I swapped hoses when I did mine but I don't think I needed to
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
toybuilt
U can use the same hoses and they go on the same way they came off, from old box to new box.
1983 Toyota Turned Chevy
KYOTA
Put a '88 box on my '83- same hoses. The fittings are different sizes for the high and low pressure sides so you cant mix them up.
