Author Topic: I love timing chains!  (Read 2685 times)
olivedrab85
  • Turtle Points: 102
  • Male Posts: 548
  • Member since Jul '05
  • "Ghost ride the whip"
« on: Aug 10, 2006, 11:20:11 AM »
I put a new timing chain in my 87 runner (22re) last night, when i started it it the tensioner went soft and chain is loose as hell. :mad: I put in an new timing kit with a lc adjustable gear, tensioner was fine when installed. I have pulled the v/c back off and tried to move the plunger in and out, it will move but still wont pump up. This is not my first timing chain install, so it is installed correctly. Any ideas of what would cause this or ideas to fix it, before i tear it back apart. Thanks
« Last Edit: Aug 10, 2006, 02:25:32 PM by olivedrab85 »
"Gotta keep it G rated for Marlin"   my runner http://board.marlincrawler.com/index.php?topic=26527.0
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: I love timing chains!
« Reply #1 on: Aug 10, 2006, 12:43:45 PM »
a small bit of sludge  clogged the tiny port for the oil to flow to the tensioner
olivedrab85 [OP]
  • Male Posts: 548
« Reply #2 on: Aug 10, 2006, 01:17:43 PM »
thanks but i fixed it. I had a wrong bolt in the cover and was hanging up the tensioner. :smack:
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #3 on: Aug 10, 2006, 02:20:21 PM »
I put a new timing chain in my 87 runner (22re) last night, when i started it it the tensioner went soft and chain is loose as hell. :mad: I put in an new timing kit with a lc adjustable gear, tensioner was fine when installed. I have pulled the v/c back off and tried to move the plunger in and out, it will move but still wont pump up. This is not my first timing chain instal,l so it is installed correctly. Any ideas of what would cause this or ideas to fix it, before i tear it back apart. Thanks
 :therethere: :shakehead:
olivedrab85 [OP]
  • Male Posts: 548
CTENG in KS
  • Male Posts: 4,295
  • ^Alfred the Great
    • CTENG's Eco-Rant
« Reply #5 on: Aug 10, 2006, 02:45:32 PM »
You jinxed yourself.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #6 on: Aug 10, 2006, 11:41:37 PM »
Hate it when that happens.
Remember to seal the threads of that top oil pump bolt or it will probably seep oil.
olivedrab85 [OP]
  • Male Posts: 548
« Reply #7 on: Aug 11, 2006, 05:06:43 PM »
Thanks ill be sure to do that. :thumbs:
RCKSQRL
  • Male Posts: 588
  • Member since Oct '02
  • Viva La Yota!
« Reply #8 on: Sep 15, 2006, 07:20:41 AM »
cant seem to find it but there was a good write up on a timing chain replacement..... unfortunately I am going to need to do this or have this done. I am not mechanically challenged but not having done it am looking for any information of doing it.
any and all help is appreciated.
'85 EFI Runner
4.3 with 700R4- for sale
5.29 detroit F/R
Front 3 Link with air shocks
rear 4 Link
Custom Fuel cell
8274
Crawler #719, rear with 4.70 # 677,
Twin stick
Skys manufacturing T-case crossmember
6 point cage modified with harness bar, dash bar and PRP seats mounted to cage
2 feet chopped off the back
It seems it is never done........
in works for new body and exo, motor and trans swap...
« Reply #9 on: Sep 15, 2006, 07:33:35 AM »
its not that bad, pm me if you need help
want2crawl
  • Male Posts: 84
  • Member since Aug '06
« Reply #10 on: Sep 15, 2006, 12:07:29 PM »
yea its not that bad ive done 2 and as long as you take your time and buy good parts you should be fine i like the double chain kit that lc sells
my biggest regret is getting rid of my 86
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Member since Feb '05
  • Full Trucker Effect
« Reply #11 on: Sep 15, 2006, 02:30:00 PM »
The double roller is the only way to go especially if you have a bigger than stock cam.
MocKKnighT
  • Turtle Points: -1
  • Male Posts: 77
  • Member since Nov '05
  • They Make Beer Commercials Like This
« Reply #12 on: Sep 15, 2006, 08:23:56 PM »
I just did the doubler roller in my truck. If you don't have any boggered threads you should be all gravy. If i told you guys how much i got the kit for with metal guide, Everyone would crap their pants, and no they weren't crappy american knock off's. Gotta love working as a parts guy at stealership!
Wheeler: 85 4runner = Fun.....
DD: 97 Taco
STOLEN AND CHOPPED! :( 84 Pickup.......22R, Weber, Lift, Winch, Gears
MocKKnighT
  • Turtle Points: -1
  • Male Posts: 77
« Reply #13 on: Sep 15, 2006, 08:30:38 PM »
If anyone ever needs me to look up some dealer only parts, shoot me a pm or call toll free at 1-888-760-8165 then ask for Sean. I'm in mon, tues, fri, sat. Metion me on marlin and i will see what kind of discount i can do! :D
DD: 97 Taco
Last post Jul 20, 2006, 07:19:15 PM
by Trunkz
Last post Sep 30, 2006, 06:56:59 AM
by 79coyotefrg
Last post Aug 06, 2008, 07:57:24 PM
by jimbo74
Last post Jan 02, 2011, 11:34:09 PM
by cdgvw1
Last post Nov 30, 2011, 07:11:05 PM
by Yota87Truck
