Need Elictrical Guru...another cheap welder adventure!
Started by CTENG in KS, August 05, 2006, 07:59:37 PM
CTENG in KS
SO...
I got myself a 120A AC buzz box from HF for the grand total of:  $68.
You can see why I couldn't pass this up.  It got here today!
CTENG in KS
It can be wored for either 110 or 220 depending onyour service...so they don't send it with a plug installed...or a plug.
CTENG in KS
This was upsetting until I heard a little voice from the corner...it was the old HF flux core welder I haden't thrown out yet wispering, "you can use my plug."  So I did.
Boy did I not have a clue what I was doing.  When I finally got it to hold an arc, all I got was birdsh!t and it felt like there was way too little current.
CTENG in KS
Then, after about two minutes my brain kicked in and I figured it out.  I wasn't pushing the rod at the arc anywhere near fast enough.  Well then I was off to the races, for 10 seconds...then the lights went out.
what kind of rod are you using??  you will NOT have enough current to run a 7018
get some 6011  in a 3/32  or 1/8
DTB
hmmmm....guess that's what u get for 68 bucks. does it come with wiring instructions at least? doesnt seem too safe to wire something like that unless your a certified electrician
CTENG in KS
It appears that I have thrown the breaker on my apt garage...this ended my night as  have no idea where the box is located.  So my quandry is this:  the welder is rated for 16A draw, I have no idea what the garage is on, I was guessing 15-16A service.  Is there anything I can do in terms of wiring, cords, etc, to get this welder to work without blowing the breakers, or do I have to go beg the office to install better wiring in my garage?
it worked,  but  if he is running a 7018  thats why he is :inthedark:
CTENG in KS
I was using the 6013 rods that came with it, they went really quick.  I have a box of 6011 on the way, but it didn't get delivered with the welder.  Imagine that.
Quote from: CTENG in KS on August 05, 2006, 08:10:06 PM
you'll need to wire it as a 220,   you get more voltage with less amperage  so the wiring in your apartment doesnt smoke
and what rod were you using??
it depends on what guage wiring is used through the apt..... if its overkill wiring, you can jsut pull the breaker in the box and replace  it, but if you dont know the wiring guage, then dont mess with it, because  the breaker will handle it, but if the wire doesnt, you could get fried wiring, and that results in fire of jsut skewed wiring and cant find whats wrong with it, as you would literally have to tear it all out and replace it
CTENG in KS
Perhaps if I turn it down a bit?  It doesn't really tell how much you are drawing, it just has that large knob on the front.
yea  i wouldnt run it more than 70%
how far is it from your apartment??
if not too far  get a 12 gauge extension cord and run it to a utility room plug  they are usually 20-25 amp 110
CTENG in KS
brainlessfool
get a big gas fired gen. one that will run your welder. it will cost about 700-1100, butt hey look at all the $$ ya saved with the welder!
BLACKDOG
CTENG, it seems as if the best option for you is seriously a generator.  HF looks like they have some decent ones for 500-700 bucks that could prolly do exactly what you need.  :thumbs:
              -Ronald Reagan
freds40
Pull the outlet in the garage you are using and see what guage wire they used. My guess is 14 guage and it's probably on a 15 amp breaker. 14 guage is good up to 15 amps. You need 12 guage to cover 20 amps. If you have 12 guage, swap the breaker and be done with it. Another option is check the panel and find a 20 amp circuit (hopefully for an outlet) and run a 12 guage power cord off it.
BTW, if your garage was properly wired, you should be looking for a GFI outlet to reset rather than a breaker. It could be on a GFI breaker but they are pricey and most contractors will save the cash on a GFI breaker and go with a GFI recepticle.
"between projects"
CTENG in KS
Thanks for all the advice...I don't know if I have access to the breaker panel, It may be in the maintenance building which is locked.  I will look around into the generator deal.
CTENG in KS
quick look at generators and I am seeing most have 110 and 220 outlets...
anyone have any experience with how large a generator to run a small welder?
Willy Mammoth
Save your money and get an onboard welder. You can use it anywhere you want and you don't need a generator. In fact it is a generator.
I just spent $835.95 for mine.
http://www.premierpowerwelder.com/index2.html
CTENG in KS
Thats a great idea for those of use who have reliably running trucks.  But what about me?
Willy Mammoth
Well? if you don't, that should be your first priority shouldn't it?  Or just get a 5 hp go cart engine to turn the alt.  :ha_ha:
How many outlets do you have in the garage? If you can find two that have the power leg on separate buss bars, you could tap into them to get 220v. But this is not recommender or code. If there is a problem you will need to hide any signs of doing this to avoid getting in trouble for burning down your garage.  :sheerterror:
CTENG in KS
CTENG in KS
OK, what are your thoughts?
I picked up one of these GCI units...it is a 15 Amp interrupt.  Question:  If the welder can pull 15-16 amps and the garage is on a 15A breaker, will the 15A interrupt switch off before the garage breaker gets thrown?
I am hoping I can use the circuit interrupter to "tune" the welder to the highest setting I can run without throwing the switch or the breaker.
