Author Topic: What can I do to upgrade my brakes on a budget???????  (Read 3584 times)
Endlessjake
  • Member since Jul '06
« on: Jul 31, 2006, 10:35:10 PM »
I have a stock 84 brake setup right now and when I brake the truck pulls real hard to the left.
So it makes me believe that I need some new rotors or have mine turned with some new pads.
BUT while I do this if I could swap some parts from other new models that work better calipers, rotors etc.
would be the time to do it.  Long explanation I know.
So can I swap anything out at the same time?
fourwd1
  • Member since Sep '02
  • Out On Bail
A common bolt-on upgrade is vented FJ rotors and IFS V6 calipers. The rotors dissipate heat better and the V6 calipers are a bit larger.
'80's Toyota 4WD P/U, Buick 231 V6, Holley 4 bbl, Weiand intake, Downey headers, custom TH-350 L/U w/700R4 low gearing, dual tanks, dual batterys, other crap ...
- - - as seen in FOUR WHEELER magazine July 2006 - -
84 4Runner ARBed 5.29's F&R, 4.7 t-case, x-over, Chevy's, 2" drv train lift, 36" TSLs, 30 spline Longs, BudBuilt skid
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
Also, get a good pressure bleeder...getting ALL the air out of the system really makes a noticable difference.
Tat2drew
  • Member since May '06
all the ifs v6 caliper kits i have seen say you will need to run wheel spacers to clear the bigger caliper
« Last Edit: Aug 01, 2006, 04:32:14 PM by Tat2drew »
"I'll keep my bible, guns, and freedom..you can keep your change"
Jedi87
I have v6 calipers on my 87 and the brakes feel better than in my trans am. It is a worthy upgrade.
87 4runner 22re bored .030,Kieth Black pistons,stage II "272" cam ,oversized valves,New amc head,ARP studs,electric fan,Doug Thorley header,
2 1/4 flowmaster cat back,5 speed,3 inch body lift,33 inch bfg m/t's.Centerforce dual friction clutch,Marlin Crawler hd-w56,Yukon 4.88's
99 4runner SR5 v6 automatic 4x4
8D3TOY
  • Member since May '05
I think you can put the larger rear drums from an IFS truck on your rear axle.
Endlessjake [OP]
So the IFS calipers bolt up exactly where the stock calipers are now?
What year FJ disks ?
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
yes they do, may have to grind a little on the dust sheild. I think I use 80 fj rotors on my 83.
Endlessjake [OP]
Thanks guys for the help I will let you all know how it turns out.
Might as well change to some stainless brake lines.
Any recommendations on where to find some decent lines?
46&2
  • Hillbilly
  • Turtle Points: 8
  • Male Posts: 4,834
  • Member since Dec '05
  • California livin'
I am running some brake lines from All-Pro. they are pretty nice, a little pricey but they are quality.
http://allprooffroad.com/index.php?option=content&task=view&id=33
rattlecanpaint
  • Turtle Points: -35
  • Member since Feb '06
I think if you use t he V6 calipers, you also have to change the master cyl.  I just did this upgrade using the rotors off an FJ80 and the calipers off a 86 4cyl 4runner and had no problems with needing a master cyl.  Had to grind some slag off one of the calipers to get the wheel to fit though.
endlessjake,   you can get new 84 rotors, DONT HAVE YOURS TURNED   :nonono:   and new premium pads  and ad a fj80 mastercylinder and you will much improve over the stock brakes, however  eveything you need you can get from Marlin
http://www.marlincrawler.com/htm/brakes.htm
« Last Edit: Aug 09, 2006, 07:40:15 PM by 79Coyotefrg »
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
Kept my stock master on my.  seams to work just fine for me.  :dunno:
i went from a 13/16 stock MC to a 7/8 MC from a celica  and MAN did it make a difference
i could throw somebody thru the windshield with a 1 inch MC
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Full Trucker Effect
I have the master cylinder Marlin offers and it stops 100% better than the stock one.
Endlessjake [OP]
Cool thanks guys for all the help
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Annihilation Fabrication
1ton chevy MC makes a world of differences  ( 1 1/8th bore)
Do you need a Hammer?
doesnt SKY  make a adapter for that ??
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Just as a thought, you say your truck pulls when braking. Is it stock or have you lifted it? If you lifted it do you still have push pull steering or have you upgraded to High steer. Now if you lifted your truck and did not upgrade to High Steer or upgrade the stock steering that could be the problem and upgrading your brakes won't help. You would be experiencing bump steer under braking.
it would pull to the right then wouldnt it,  i know mine will pull to the right if i stab the brakes hard
  • Momentum Man
  • Lego Enforcement
I've heard of it doing it either way depending on how high you go, 3 inch lifts tend to send you right, 5-6 will change things since when you go that high most people also remove the torque rod. This does only apply if you have push pull steering though, so if it has High Steer my point is mute.
IronClad
  • Male Posts: 2,284
yeah and rockstomper does too.. or you can make one out of a piece of 3/8ths plate like me..  the MC was given to me and i had the plate so i had nothing into my swap.
i have a chevy MC  maybe i'll do that,  just for research purposes of course
wmflyfisher
  • Turtle Points: 89
  • Male Posts: 194
  • 85 Pickup, 94 4runner
Does anybody have the part numbers for these pieces? I work at a parts store and could probably cross the numbers and save a little $!
wmflyfisher
  • Turtle Points: 89
  • Male Posts: 194
just look for 97 FJ80 landcruiser 4wd  non abs
Last post Jan 13, 2011, 10:16:30 AM
by yoshaleng
Last post Feb 09, 2007, 05:17:09 PM
by hiluxtrux
Last post Mar 03, 2011, 03:06:49 PM
by BigBs84
Last post Oct 17, 2008, 09:20:36 PM
by AaronB
Last post Oct 24, 2008, 08:31:19 PM
by chevihemi
