22re problems I need some help
Started by yotakid88, July 21, 2006, 12:55:19 PM
yotakid88
well I just finished rebuilding my re and I got it in and every thing and she started rate up but acording to the oil presser gage in the truck it doesnt have any presser and the is a knocking noise in the second and third cylender area. so any help would be nice thanks.
got low range
95/91 pickup, 3in tuff country lif and a bunch of marlins stuff.
Weldo
mudmaster
You did use a new oil pump, right?
Time to go wheelin!
unclejpl4x4
your best bet is 2 get a oil p-gauge  and see what your pressuer is .   take out the sender and screw in the p-gauge hose/gauge
also did U fill the oil pump up with grease ? 2 prime it
yotakid88
well it has a new oil pump. the vavle lash is set corectly and I am going to try to get a p-gauge
got low range
Weldo
It's possible that your oil pressure gauge isn't working.  I think mine is busted.  I used to have a normal gauge cluster and the oil light never came on at all, so I figured I had good oil pressure.  Then I switched to an SR5 style cluster and the oil pressure needle just barely moved from zero at like 4000 rpm, and now it stopped moving all together, so I think my gauge is bad.  I believe there is a way to test the gauge, and I think it's by grounding the oil pressure sender wire to the frame or something, not totally sure.
h0nke
You have the correct rod/main bearings for your crank?
1980 SR5 shortbed pickup (Project Rust Bucket)
yotakid88
yes I have the correct rod/main barrings. and I also think that the gauge in the dash is busted.
got low range
Skinny_Pedal
knocking's not good. when you started it up was the knocking immedite? did you break in your cam yet? if so have you driven it around for 500 miles changed the oil? typically a KNOCK! is a shot bearing
Im an OG
Weldo
My old motor was knocking and this is what I found on the #3 connecting rod journal.
unclejpl4x4
Duffil
Did you just bearing this block, or was the crank miked and possibly ground?
What I'm getting at is, if the crank was out of tolerance, and you threw standard size bearings in it...
unclejpl4x4
Quote from: Duffil on July 23, 2006, 01:48:23 PM
ya good piont
hay yodkid  how about a little more info  like how did You rebuild it?
Did you use a micromiter or gauge strips  was the block cleaned/ wet the barrings  and so on . ( more info the better)
yotakid88
well the problem has been nerrowed down and figured out and the vavles just need to be adjusted agen but I will tell every one the facts about the motor. It was hot tanked and bored out to .30 over and dected by my couson's machineing class (the teacher has been building motors for over 30 years and he does race motors now). then once it was brought home my dad and I put in the crank and pistons.(my dad is ase seritfyed and has built meny a motor in his day). then I finished the rest of it off by the book. the cam I a loow to mid range. the crank has the std size barrings. and the crank was in emiculent condition so we put it in.
got low range
unclejpl4x4
hay did you use new rockers ?  for the new cam ?  please tell me yes
yotakid88
no the ones that I have are like new.
got low range
Stinky
the knock...if it isnt really loud, but barely audible, then its just piston slap....does it do it mostly when cold n rite around idle...then thats all it is...i kno a guy who has been tinkerin with toys since they first came over here n he knows his :pokinit:....not a biggie....BUT if it is VERY audible, like with the windows UP, then u got a bad rod bearing, wrist pin, wrist pin bearing....unbalanced crank.......a few things
87 p/u SAS, 22RE, built, then cut up and scrapped
94 ex cab P/U, SR5, fully loaded, 3.4 swap, r150f, a/c, bumpers, 33s, glass fenders...sold
00 Stoopid Duty 250, ex cab, lariat, v-10,000
94 reg cab, 22re, duals, 38.5 boggers, sas, 4 link, tube bed, build underway... http://pirate4x4.com/forum/showthread.php?t=967836
88 Samurai, soa, buick 3.8, th350, zuki case, 1/4 done... anyone wanna buy it??
yotakid88
yeah we figured it out like a cuple weeks ago its the wrist pin bussing on the fourth cylinder. it got mechined out just a little to much.
got low range
unclejpl4x4
well glad 2 hear U found it :woohoo:
so is it fixed yet ?
yotakid88
no but I got another truck that me and my dad are going to try to reserect and if that doesnt work its gunna get a 3rz.
got low range
