Author Topic: shock hole?  (Read 3735 times)
RustyToy
  • Turtle Points: 481
  • Member since Dec '03
shock hole?
« on: Jul 09, 2006, 06:08:19 PM »
Anyone know what this is all about?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: shock hole?
« Reply #1 on: Jul 09, 2006, 06:11:58 PM »
the hole in your inner fender ??   from the shock bottoming out and pushing the tower over
you need shock hoops or a modified shock tower
RustyToy [OP]
Re: shock hole?
« Reply #2 on: Jul 09, 2006, 06:15:13 PM »
but its only on that side...  time to get longer shocks then.
Re: shock hole?
« Reply #3 on: Jul 09, 2006, 06:21:05 PM »
it will eventually do both sides when you play hard,  longer will def  have to have longer hoops
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: shock hole?
« Reply #4 on: Jul 09, 2006, 06:26:35 PM »
Won't be long before you rip that shock tower off. It will usually take a good chunk of the frame with it. Basically what is happening is your shocks are bottoming on that tower causing it to flex, it will keep twisting until it breaks free. The other side will eventually start doing the same thing as it weakens from the flex.
RustyToy [OP]
Re: shock hole?
« Reply #5 on: Jul 09, 2006, 06:51:14 PM »
I was thinking the body was dipping... is that a abstract theory?
  • Momentum Man
  • Lego Enforcement
Re: shock hole?
« Reply #6 on: Jul 09, 2006, 07:11:47 PM »
There could be a little body flex invloved but not likely that much. Do this so you are certain as to the problem. 1st cut those stupid boots off, next take a tiewrap and attach it to the exposed rod right at the end of the can, now take it out on a run and see what happens to the tiewrap. If it gets smashed or completly disapears you know your shocks are bottoming. You may be able to tell just by cutting the boots off if you can see a dirt line on the rod. If it is 100% shinny it is bottoming.
RustyToy [OP]
Re: shock hole?
« Reply #7 on: Jul 09, 2006, 07:19:20 PM »
I love the excuse to buy new shiny parts... thanks
Rockdiver
  • Turtle Points: -118
  • Male Posts: 671
  • Member since Apr '04
Re: shock hole?
« Reply #8 on: Jul 09, 2006, 07:29:37 PM »
Looks like the top of the shock is not tight enough      tighten the nut on the top to pull the bushings on the shock down a little
  • Momentum Man
  • Lego Enforcement
Re: shock hole?
« Reply #9 on: Jul 09, 2006, 07:33:38 PM »
I've had them get loose and they rattle like crazy. He didn't say anything about any noise. They could be a little loose but not bad.
RustyToy [OP]
Re: shock hole?
« Reply #10 on: Jul 09, 2006, 07:54:26 PM »
the rubber bushing are smushed... i think its tight, i'll try to make it tighter...
  • Momentum Man
  • Lego Enforcement
Re: shock hole?
« Reply #11 on: Jul 09, 2006, 08:11:13 PM »
Just grab the shocks and push them around, if you can move them easily in their mounts then they are loose if not they are tight.
RustyToy [OP]
Re: shock hole?
« Reply #12 on: Jul 09, 2006, 08:22:10 PM »
okay so with a 4 inch lift i should get the 12 inch shocks I'm thinking
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
Re: shock hole?
« Reply #13 on: Jul 11, 2006, 01:38:01 PM »
Tighten that nut down!  It's barely on there!  I used to put shocks on at Les Schwab.  Tighten it up, till the rubber bushing has flattened out to slightly larger than the metal washer!
Last post Oct 04, 2011, 07:31:54 AM
by sjelite
Last post Jan 23, 2014, 07:58:52 PM
by 69sixpackbee
Last post Feb 25, 2014, 08:26:04 AM
by Nation
Last post Jul 17, 2015, 12:36:36 PM
by TheeMikeB
Last post Aug 13, 2015, 01:13:19 PM
by 84Flatbed
