5.0 HO swap questions
Started by oz31p, June 10, 2006, 08:05:37 AM
oz31p
im planning on swaping out my 22re for a stock 5.0 ho from a 1989 linclon mark 7 lsc(i have the entire car(((factory 9 in with disks )))). but i have a few questions:
i have heard that the 87,88,89 5.0 ho's from the LSC have bigger heads,bigger fuel injector equaling a boost hp an tq over a standard HO. is this true??
i want to make it an auto and keep my yota tcase so my best options are(correct me if im wrong) aod if i want od, or a c4. when i source the trannys do they need to be a 4x4 model or will a 2wd model from a car work with the addapter from either advanced adapter or northwest offroad?? is a ford c4 worth a damm?
i have a sas planed first so the oil pan clearance should not be a issuse. i read a post on yt about somthing spiecal about the accesory brakets from a lsc, but i could not understand what was meant. can some one explain it alittle better.
their was a few more things but i cant remember what.
thanks for your info in advance
JUST THE TIP, JUST FOR A SECOND, JUST TO SEE HOW IT FEELS.
alpha_radiation
The lincoln ho is just an ho engine.  It might have forged pistons, I can't remember.
I believe that advanced adapters makes an adapter for the AOD/toy case, but its up around $500.  If you have the 9 and have to swap the front, I would just run a 44 and a 205/208.  It will be cheaper in the long run, and alot easier.  The c4 is a better tranny than the AOD, but you won't have od.
Be prepared for a lot of work to stuff the 5.0 in.  At least ford makes the stand alone wiring and a sensor kit.  I would spend the money on that just to make it easier.
I would do a lot more research on this swap, go to pirate4x4 and check it out.  This is no easy swap.  I was looking into this, and discovered that the 3rz is a better option.
Here is the link for pirate
http://www.pirate4x4.com/forum/search.php?searchid=136370
Quote from: Engineer Ben on June 10, 2006, 11:40:52 AM
If you are looking for information on the 3RZ, then you don't need to look any futhure than where you are already at. :duh:
Please see: The Official 3RZ Knowledge and Database Thread
alpha_radiation
That, and the shop isn't very far from my house.  If I can't get the 22re to pull more than 45 up the 4 lane I will wait on the dual case and do the 3rz swap.
oz31p
thank you for the info. i may have to sell the 9 for some cash still not sure. if i have od or not im realy not worryed about it. i would rather not have od and a strong tranny.
6.72:1
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
Couple more from his thread:
Here is another (non-updated) link from Brandon: http://www.pirate4x4.com/tech/Engine/index2.html
oz31p
ya thats more than a little motivation
i secretly what to pull a wheelie in a 4x4 !!!!
oz31p
hey mike is that a custom allstar under cat1 in that last pic??
if so im not sure where i can source a pair of oldshool converse
