Author Topic: 3RZ info  (Read 2931 times)
hopper
  • Male Posts: 143
  • Member since Feb '06
3RZ info
« on: May 25, 2006, 06:47:08 PM »
Is just the engine wiring harness enough wiring to do the swap?     thanks for the help
hopper [OP]
  • Male Posts: 143
Re: 3RZ info
« Reply #1 on: May 25, 2006, 06:52:09 PM »
if not how much would a whole harness be?
8D3TOY
  • Turtle Points: 5
  • Member since May '05
Re: 3RZ info
« Reply #2 on: May 25, 2006, 08:40:44 PM »
No, you will need the engine also, see the sticky up top,read,learn,ask.
hopper [OP]
  • Male Posts: 143
Re: 3RZ info
« Reply #3 on: May 25, 2006, 09:45:08 PM »
Im am confused. :headscratch:   I know I need the engine but I was asking if I needed more than the engine wiring harness and the ecu+wiring for that.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
Re: 3RZ info
« Reply #4 on: May 25, 2006, 11:52:52 PM »
If you live in California you will also have to swap in the evap system of the donor vehicle.  Dont' forget about the alternator, p/s pump, a/c compressor, bellhousing, flywheel and clutch - not to mention the minor fab work you will need to do on the motor mounts and various other things.  :hammer:
hopper [OP]
  • Male Posts: 143
Re: 3RZ info
« Reply #5 on: May 26, 2006, 12:10:58 AM »
I live in Las Vegas so that shouldnt be a problem.  I dont have p/s so that can be checked off, I dont have a/c right now so none of that and im keeping my tranny and the bellhousing will be included in the sale.  I know some good fabercaters for the motor mounts.  I figure it will be rather easy :disturbed:
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
Re: 3RZ info
« Reply #6 on: May 26, 2006, 06:39:35 PM »
Yeah, motor mounts are easy.  I just did like BigMike did in his 3rz swap and cut the stock ones off the frame, hacked about an inch off the backside and bolted them to the motor.  I bolted the motor up to the belhousing with trans mount in place and lowered it down to where I wanted it to sit and then started welding in the mounts.  It was pretty easy, but I'm not the best welder, so the welds look like bird crap. Oh well, at least they aren't going anywere.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
Re: 3RZ info
« Reply #7 on: May 26, 2006, 06:41:15 PM »
What year is your truck anyway?  Depending on the amount of lift you have, you might need a different oil pan off of a T100 with a 3rz.
hopper [OP]
  • Male Posts: 143
Re: 3RZ info
« Reply #8 on: May 26, 2006, 06:43:07 PM »
Mine is a '85.  Ya I know that i will need the T100 oil pan, dip stick, and pickup.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
Re: 3RZ info
« Reply #9 on: May 27, 2006, 06:14:53 PM »
If yours is a fuel injected '85 then you should be able to wire it with using just the 3rz engine wiring and the teh stock '85 engine bay wirring harness.  At least this is what I am working on slowly but surely.  I have the dash harness out of a taco too, so I am planning on using the connectors that hook to the ecu for OBDII and for power/ground/fuel pump if needed and a tack signal.  Hope this works out...  :crossed:
hopper [OP]
  • Male Posts: 143
Re: 3RZ info
« Reply #10 on: May 27, 2006, 08:32:39 PM »
no its carbed. :sad2:  Good luck on yours.   Do you have a thread going about your swap?
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
Re: 3RZ info
« Reply #11 on: May 27, 2006, 10:50:02 PM »
Yeah, but I didn't get too far though.  I got a girlfreind and don't have much time for it anymore.  The way I look at it, once I get it running, the rest should be easy.
A cool trick I figured out was to use the taco alternator, since the 22re won't fit right.  In order to use the '85 charging system setup, you need to swap over the diode pack on the back of the taco alternator to that of the '85 for the '85 harness plug to work.  I think I still used the taco brushes though.  Then you have to awger out the plug hole on the diode cover for it to fit right, but it should work fine.   Just my  :twocents:
Last post Jul 27, 2006, 01:23:57 PM
by Plowking
Last post Feb 09, 2012, 03:07:11 AM
by zippo
Last post Jan 23, 2012, 05:59:41 PM
by 4RunnerChevy
Last post Aug 19, 2012, 06:45:59 AM
by toygasm
Last post Nov 09, 2012, 08:57:11 AM
by OOPS
