clicking noise
Started by motorider228, May 10, 2006, 09:34:13 PM
motorider228
when I drive slowly in my 98 dodge ram it starts making this weird clicking noise that sounds like it's coming from the driver rear side of the axle. I have no idea what it could be  :dunno: it could be coming from anywhere in the back though. Only happens when I drive slow though. The axle is a chrysler 9.25 if that helps anyone.  It almost sounds like when you have a milk jug full of water and tip it completely upside down and let it glug out.
Willy Mammoth
The only thing that comes to mind is the brakes. Maybe a pad is loose and moving in the bracket. Try to hold the brakes lightly and see if it stops making the noise. If you have drums, then pull them and look for any parts that may haven fallen off into the drum.
You also may want to get on a Dodge forum and ask the same question.
Do you have rear disc brakes? If so then I'd be thinking the same thing WM is, loose brake pad. I've never heard of a drum shifting back and forth since all those springs hold everything tight. Now if a spring broke then they can move around but would make noise all the time.
motorider228
The rear is drum. I will have to check but I believe the noise does stop if I touch the brakes lightly. I will check next time it makes the noise and get back to you.  I tried posting in the dodge section on pirate but it wouldnt let me post threads.
motorider228
well it made the noise for me on the way home from work tonight and i touched the brakes and the noise continued. I will try posting on pirate still if it will let me, not sure whats up with that. Unless any of you guys know of any other dodge forums. Thanks for the help though and thanks for responding to my question and not leaving me hanging.  :beerchug:
alwaysbroken
i had a 2001 dodge ram extra cab long bed, it was doing the same thing and it turned out to be the center carrier bearing.. i hope thats some help...
89 4 Runner, 3.0, 5spd, 2.28 crawl box, 4-1 atlas, prorock 60 up front, crd60 out back, on 37" mtr's
motorider228
#6
thanks man. how much was that to replace? Should I just take it to a diff shop or driveline place because i'm not too keen with differentials.
alwaysbroken
The center carrier bearing is on your drive shaft. It cost me about 100.00 from the dealer.
you can do it your self it will safe you money, but if you can't take it to driveline shop.
But i would double check to make sure it's bad...
motorider228
Yeah i'm yanking the driveline tomorrow because some guys on another forum told me theirs started doing the same thing and it was the rear U-joint, I think i'm going to put a new U-joint in anyways. What should I look for in the carrier bearing to make sure it's bad enough to have to replace?
motorider228
#9
this post is no longer neccesary because i was wrong
