Author Topic: wtf please help my truck sags horribly to the drivers side  (Read 10753 times)
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
the hell are you talking about? the shock in place of the torque rod allows for more droop if thats what your referring to. im confused from your rambling dry jokes.
I'm with you on this, I did the shock/steering stablizer torque rod setup and it does work.
84_yota_4wd [OP]
  • Turtle Points: 219
  • Male Posts: 831
  • Member since Feb '06
  • mountain goat
    • Buy me some coffee
no those were new springs. what a cut valve no!!!!!!!!!!!!!!!!!!!!!!!! f@ck i cant afcford that i sure as hell hope thats not it. r u sure um it only does it now if i floor it in first gear past 4000 rpm
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
i was referring to you putting the sway bar back on to fix your sagging springs  :smack:
i too have a shock  but its a long one and the mount is under the radiator now
eightyfive
  • Turtle Points: 232
  • Male Posts: 552
  • Member since Dec '05
i put the sway bar on to fix body roll? it just so happened to fix the lean. stoked about that.
oh, and my springs aren't sagging, i said i just lifted my truck...
._________________________________________.
||____________||____________||___T0Y0TA__||
||____________||____________||____________||
1985 TOYOTA 4RUNNER
some modifications here and there....
  • Momentum Man
  • Lego Enforcement
The problem I see with that cure would be that the swaybar mount would not be strong enough to hold the load that is being applied to it if it is pulling and or pushing the supension to level it out. Just like a shock tower is not a bumpstop and will rip off the truck if used as one.
eightyfive
  • Male Posts: 552
totally understand. it's just when i put my sway bar back on, it leveled out the truck, WEIRD. hey, since it worked for me, i say give it a try. (its not going to cost you anything)
1985 TOYOTA 4RUNNER
84_yota_4wd [OP]
  • Male Posts: 831
  • mountain goat
yea true i had it on for awile back when i only had 4" of lift and i sat uneven then too thanks though
Marlin Crawler
Last post Dec 29, 2004, 09:36:49 AM
by 98runner chevota
Last post Apr 28, 2005, 11:11:14 AM
by DeMented Toys
Last post Oct 15, 2008, 06:34:11 PM
by jimbo74
Last post Mar 22, 2011, 05:38:01 PM
by VLP
Last post May 05, 2015, 01:13:45 PM
by trash1stgen80
