22r noise???
Started by GoaT, April 27, 2006, 09:02:15 AM
GoaT
MY 22r makes alot of clater sounds like in the head.
i was told thats common but its loud!!!  :shocking:
valve adjustment? or is it just how it is?
Wermz84
Quote from: GoaT on April 27, 2006, 09:02:15 AM
They all make a bit of noise, but checking the valves is easy and would be cheap insurance.   :thumbs:
Hopefully it isn't your timing chain slapping around cuz the guide is gone. My last engine sounded like a diesel because of that.  :twocents:
I like to Drive!
pull your valve cover and see what wiggles :wiggle:
GoaT
Quote from: Wermz84 on April 27, 2006, 10:21:45 AM
damn it that is what t sounds like. !!!!!!!!!!!!!!!!!!!!!!!!
874runner
Mine does the same thing.  I hope its not the timing chain :crossed:
If it is the timming chain get it fixed before it eats a hole in the cover. I have unfortunatly done that one, started while I was wheeling it in Truckhaven and by the time I got to Cherry Valley I was spitting oil all over the place.
unclejpl4x4
lol U can hear my valve train over the radio and worn/chopy tires   runner :burnout:
get a gasket  and pull you cover check you dangle  ajust........ still will be noise after
GoaT
k i does sound like its coming from the front of the motor.... but yah. is there any right ups on how to adjust u valves?
Quote from: GoaT on April 27, 2006, 03:17:34 PM
If it's the front of the motor it is more than likely the timing chain, adjusting the valves won't help.
unclejpl4x4
goat is it more of a ticking sound ? from up front ? then it's the chain.  but do your valves.
There realy is no trick , motor warm   and a feeler gauge 2 sizes  start at top dead center  and do the in/ex  valves U can get  then flip er over and do the rest.
Wermz84
Quote from: 79Coyotefrg on April 27, 2006, 10:58:03 AM
I see the problem know, there's these little rocking things in here,  I'm gonna go and pull em out!   :hammerhead:
Quote from: Rocksurfer on April 27, 2006, 03:02:47 PM
:werd:  It would suck to spring a leak!   Oil RS? :headscratch: I thought the leak would be from a water jacket.  :dunno:
http://board.marlincrawler.com/index.php?topic=5743.0
maybee that helps, definatly warm.  I just did mine.  .008 intake, and .012 exhaust I believe.  Is that right everybody?
I like to Drive!
Quote from: Wermz84 on April 27, 2006, 05:05:20 PM
It all depends on where it makes the hole, if it takes out the front of the cover you'll get water and oil mixing inside, if your chain bangs the side it will gnaw a hole that will spit oil all over the place. Fortunately lots of RTV will fix it enough to get it home if it's on the side of the case.
unclejpl4x4
more or less  wermz    but some times U just got 2 go by sound.
and yes if it is the chain don't wait 2 long   the t-cover on my celica broke while i was doing 70 on the highway  needles 2 say i was at the j-yard geting a new moter.
Wermz84
Quote from: Rocksurfer on April 27, 2006, 05:10:03 PM
:think:  Ah yes thanks.
Well Goat what did ya find out?
I like to Drive!
Wermz84
**Revive**  But now I'm having the noise!
Problem -- Loud ticking, clicking type noise, mostly under acceleration.
Checked -- Timing = 5 Deg BTDC
                Valves = Just got done rechecking them.  All good, one a tiny bit loose, one a tiny bit tight
OK, everything leads me to think the timing chain guide.  I shined a flash light down there while the cover was off but they looked ok.  even poked at them with a screw driver, no movement.  Any thing else I can test before I just tear it apart?  Maybee there broken lower.  Maybee the tensioner is stuck and it's slapping against the guide??
I did just notice puting it all back together that my air box has a 7" crack on the bottom around the carb.  :haha:  could this be affecting my vacuum advance?  don't think so?  Could explain why I only hear it under ecceleration.  :dunno:    going to buy a new box tomorrow after the holiday..
I like to Drive!
johnboy
Its sounds like your timing chain guide is broken below your view. mine broke about 3 weeks ago, cost me a new timing chain assembly (crank & cam gears, guides and chain) some JB weld (to fix the crack in the front cover)2 head gaskets, #4 intake vavle (<<my fault) 38/38 weber carb+offenhauser intake, and oil. all in all about $500+ dollars. bwst thing to do is buy the timing set, but make sure to buy a head gasket,oil pan gasket, sealant (right stuff silicone or gaskecinch) and a 18 paxk of beer before its too late.
1985 toyota STD cab locked up w/ 35's
http://www.whore4x4.com/
Ezekiel 25:17
The path of the righteous man is beset on all sides by the iniquities of the selfish and the tyranny of evil men. Blessed is he, who in the name of charity and good will, shepherds the weak through the valley of darkness, for he is truly his brother's keeper and the finder of lost children. And I will strike down upon thee with great vengeance and furious anger those who would attempt to poison and destroy my brothe
RustyToy
hey! take a long screw driver and listen to your fuel pump...
Wermz84
Quote from: johnboy on July 06, 2006, 03:09:36 AM
this is kinda what I was thinking.
Quote from: RustyToy on July 09, 2006, 05:43:12 PM
Are you being serious?  If so how will this help please?  :dunno:
I like to Drive!
RustyToy
Those fuel pumps can get really loud.  :hammer:
wermz, youve never heard of the long screwdriver trick? its an old mechanics trick...... basically, it acts as a stethoscope and intensifies the noise, it also wont pick up all noise, and pretty much just picks up what you touch the end to
GoaT
ok. so i replace the timing chain.
i broke a guide
and almose tore up my cover. it was pretty damaged but nothing jb weld wouldn fix :).
only think now is my oil pump is making a lil bit of noise. like tiny ballberrings spinning around. should i be worried?
ah and the head still make a lil noise buy not scary  just like a sewing machine.
i have a good timing cover,  send me $20  and its yours,   i'll pay the shipping
or  better yet  i'll save it for ya till Halloween at Gilmer
GoaT
where is gilmer? and ill just leave it. dont feel like pulling the head again
Quote from: GoaT on August 15, 2006, 06:38:39 PM
Gilmer Tx  you ninny,  um  its  north of Longveiw
did you clean pout the oil pan? if you broke a guide, that menas there a bunch of little pieces floating around..... and that noise could be that, or oil starvation, as those little pieces can and will clog up oil passages
:smack:  i hate to say it but yea Jim is right :yikes:
make sure you got those pieces out
4inchToyotas
Sewing machine = typical 22r from my experience. Mine sounds like a diesel a lot but that's due to the cam and head, since it was rebuilt before I put in in.
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
Quote from: 79Coyotefrg on August 15, 2006, 06:59:15 PM
Now look what you did his head swelled up like a balloon, but since Glen let the cat out of the bag you do probably have some shavings in the pump and would be something to be worried about.
