Check the axle shaft to see if it is warped, but more likely the housing is bent on that side. Running it that way will prob kill the side gear in your spooled diff. If I was you I would be either looking for a new housing, or you could always be ghetto and try to warp your housing back into shape by welding a few beads on the outside of the curvature...that might make it for a weekend...
look at the welded seem on the front of the axle tube, if its bent your axle is too
yea a little better every day, sure miss the old
Started by dentedfender Engine
Started by Siringo Toyota Pickup/4Runner Tech 1979-95
Started by Nor-Cal Toy Toyota Pickup/4Runner Tech 1979-95
Started by quartz Toyota Pickup/4Runner Tech 1979-95
Started by Rock4Runner 1984-1988: How-To Guides
