oil explosion
Started by pickemup81, April 22, 2006, 09:35:04 PM
pickemup81
The other day when i was heading home my engine started gushing oil out of the top of the block. It looks like it were somewhere around the intake and the head. It didn't seem to loose power or anything. I haven't had time to look at it due to work so any help will be much appreciated.
86 4runner now with sas and other garbage
intake and head, are you thinking the valve cover gasket? if gushing, decribe what you are talking about a drop or 2 or a qt of oil on the ground?
pickemup81
its not as high up as the valve cover it is right behind the intake around the bottom of the head im pretty sure. like i said i have not had much time to look but that was the area i noticed. the oil dumping quarts out just at an idle.
Shamb
rear main seal?
if its gushing that bad it might have blown completely out.
RustyToy
it sounds like your oil pressure gage came out... that will send a spray all over the place! good thing is you know you have good oil presure
RustyToy
i'm not awake yet.. not oil gage oil pressure sensor....  YAWN
The valve cover could have come loose, not that uncommon, tighten them and see.
egr  bolt nearest the intake  probably came out,  if so  oil will run out that hole befor going back to the pan
:yikes:
RustyToy
what ever you do don't drive it before you get thing figured out...
pickemup81
I dont have to work today so here in a hour or so I will go get it fixed. If you guys think it might be something else just keep em coming. I want to get it fixed and get out. Thanks fellas
pickemup81
Thanks for your input. It turns out that all it was is the rubber seal on the oil filter that had a 2 inch crack in it. Thanks for your help.
thats good that it was jsut that, hopefully you noticed things before it poured out too much oil and the engine is still ok, keep a look out for problems
