Heres what you got stock. as you can see theres very little room between the bracket and top leaf
Use a long strong flat head screwdriver or pry bar to lift bracket up a little
Take your screw drive and pop off the plastic piece. they are no longer needed.
As seen in this photo there is already a hole so no need to drill.
Take a pair of channel locks,vise-grips,or some type of pliers to bend up bracket.
Here you will need a rod or screw driver thats strong and just small enough to fit in the pre-existing hole.
Put the tool in the hole and press down.it will probaly bend the whole bracket down,you then use a hammer to get it back up.
Here is what it should look like after you bend them down and beat them back up.
Here it is.Finished and ready for fun.
~Tools needed:strong flat screwdriver or prybar,some sort of pliers(channel locks and vise-grips),ratchet and wrench.
~Parts needed:4 Grade8 3/8 x 3 1.5" bolts
4 Grade8 3/8 nylon locking nuts (home depot does not sell grade 8 bolts lowes does)
~Total cost: $11
Any questions or ideas please Post Or PM. GOOD LUCK
