Center pin on a 6 leaf pack
Started by J-BO, April 21, 2006, 07:36:08 AM
J-BO
I am adding a 6th leaf to my rears up front pack on my runner to add a slight lift and increase the spring rate.  I don't think my center pin is long enough, i havn't looked though.  Do any of yall know a source for longer center pins?  I guess marlin's spring pins would work.
1985 Toyota 4Runner
22RE, 63" chevy's out back, hybrid rears up front.  36" IROKs, dual stock cases, Lincoln locked rear, and Aussie locked front.
2005 Chevrolet Silverado 2500HD DD/TR
6.6L Duramax Turbo Diesel, 6" Rancho Lift, Edge Juice Attitude Programer, 35" MTZ's.
synwars
Try looking first. :headshake:
You can get longer center pins from any spring/suspension shop. 4" 6" & 8" are the lengths I've seen before. A 4" should be fine though... 5/16" hole I believe is Toyota version.
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
DAWGTOY
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
i got mine,  from Crowburlingame/bumpertobumper
i got a box of 8    8x3/8 grade 10  leafspring tie bolts for $20
i got allen head cap screws @ the hardware store with metal locknuts for mine, they cost like $1
whiteman
Most auto parts stores, ok maybe not shucks, but NAPA.
dont make the mistake of using just any bolt jim
Quote from: 79Coyotefrg on April 21, 2006, 06:34:33 PM
Ditto that, it won't last long, and the damage it may do is not worth the 3 bucks you saved.
