FATBOY's 85 Makin' Progress
Started by FATB0Y, April 12, 2006, 05:11:46 AM
FATB0Y
FATB0Y
I got my gas tank and skid plate put back on yesterday and now my carb. is acting up :sad2:
FATB0Y
gonna pull the carb off 2morrow and see if I can adj. the float.  :_order:
does anyone know where I can find correct carb adj. online ?
FATB0Y
I found the paperwork that came with the rebuild kit. I took the top part off the carb yesterday and checked the float and it is dead on the money. I have no Idea what is wrong with it.It is almost like it is vaporlocking but it will do it even with the gas cap off. Anyone have any Ideas?  :help:
FATB0Y
A friend of mine and I rebuilt the carb on my 85 a while back and It has problems.It will start fine and Idle fine I can drive it around the yard but as soon as I pull out on the HWY it starts acting stupid like it is outta gas. (Yes I've replaced the filter)
FATB0Y
Quote from: michaelfinn on January 07, 2007, 09:05:43 AM
did you have this problem before you rebuilt it.
It would only run as long as you poured gas in it B-4 the rebuild.
mickeyfinn
i assume the carb sat for a while and it was gummed up pretty bad.
FATB0Y
Quote from: michaelfinn on January 07, 2007, 09:14:27 AM
yup  :yesnod:
mickeyfinn
have you had it apart again since you did it the first time. does it run out of steam on acceleration and missfire or does it buck and carry on like a missfire all the time. also does it ever backfire through the carb?
FATB0Y
when I pull out on the hwy I can nail it and leave two black marks about 50 ft and shift to 2nd gear and nail it again then as soon as I put it in 3rd gear and nail it again it starts to sputter like it is outta gas.
mickeyfinn
thats about the time the secondary opens up. is the secondeary plate free? the way to check the secondary without driving the truck, is take a rag and restrict the primary while revving the engine. the secondary will open and the engine still run. restricting the primary is to keep the engine from over speeding. hold the engine about 2500-3000 cup the rag over the primary and increase the rpm. if the secondary is working it will continue to run. caution!!! don't do this very long. you should be able to tell faily quickly
FATB0Y
Quote from: michaelfinn on January 07, 2007, 02:46:00 PM
thats about the time the secondary opens up. is the secondary plate free? the way to check the secondary without driving the truck, is take a rag and restrict the primary while revving the engine. the secondary will open and the engine still run. restricting the primary is to keep the engine from over speeding. hold the engine about 2500-3000 cup the rag over the primary and increase the rpm. if the secondary is working it will continue to run. caution!!! don't do this very long. you should be able to tell fairly quickly
Thankx tried what U said and the secondary works.
I think I might end up doin' what I did on my 82 Datsun and put a 350cfm Holley on it and be done wid it.
mickeyfinn
have you had the carb apart since the first time you built it
FATB0Y
yeah I took the top half off yesterday to check the float
mickeyfinn
does this carb have an internal power valve or is it vacuum. did you go through the jets again.
FATB0Y
Quote from: michaelfinn on January 07, 2007, 03:55:10 PM
this is a pic I found on e-bay of an 85 carb I assume the valve you are referring to is the one on the front with the black and white wires goin' 2 it.I have checked it a while back and it checked out.
FATB0Y
I GOT MY TRUCK RUNNIN'  :woohoo: :woohoo:
Found a vacuum leak  :smack:
DAWGTOY
allrighte now. get her done so you can go with us
to crozet in feb.
dawg
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
FATB0Y
I'm not gonna have it ready by then. Plus I can't get off work  :sad2:
FATB0Y
I can't seem to get anything done. I wanted to work on it this weekend but I had to work over today and I need my  :sleepy:
FATB0Y
I havent had a day off in 3 weeks :sad2: But I did buy a 84 sr5 x-cab parts truck :gap:
