Knuckle Ball Gusset Kit
Started by CruzrDave, April 06, 2006, 03:06:27 PM
CruzrDave
Check these out. I have bent my last housing.
Even with a lower or upper axle truss the front axle can still bend. These gussets strengthen the last weak link on your axle housing. They fit Toyota FJ40, 60, 62 Land Cruiser or pickup/4runner axle housings and include caps for the steering stop. Because of the size of the upper gusset and the location of the lower shock mount on Pickup and 4runners axles we have incorporated a new lower shock mount of the upper gusset. This upper gusset features a single shear lower shock mount (This is similar to the Land Cruiser).
Upper and Lower gussets are made of laser cut 3/8" steel while the steering stops are cut from ¼" steel.
Note: Some grinding may be needed to trim to fit these gussets. Welding, cutting and grinding required.
Taking back America, one part at a time! :madeinusa:
MiniSimp
I like them, but would like them more if there was another tab to weld on for the other side of the shock bolt.
Kris
i just bought the kit and am a little confused on how to put it on.  Don't want to sound stupid but new to the toy scene and have no clue what the land Cruiser front shock setup looks like.  Do I cut the hole shock tabs off and center the gusset on top and weld the circle tab on the back.  I don't want to mess it up.  Do you guys have a pic of it in stalled?  Please help! Oh and by the way got my shipment to day and everything is great craftmanship.
Better to be judged by twelve than carried by six!!
You can grow, You can hide it, You can build it:
BUT WE WILL FIND IT!!  K-9
:yikes:   um ok ive seen these on the Ftoy,  Kris i would think you could cut the one side of the shock tab off and put the gusset there,  then the bottom one in the center
Kris
Dose it have to be in the middle and what about the circle tube?
Kris
Look at the pic on marlin sit and it is a circle tube.  I think it gets weld to the back of the gusset
i mean the gusset for the bottom of the knuckle,  center that one
the top,  i havent seen the kit so i dont know what they have,
if it was me,  i would put 2 on top so i could put the shock between them :think:
ok, let me go see what they have brb
hey do you have a welder??
Kris
Getting the lincoln 175 in a couple of days
#10
oh ok i see what you mean,   let me get one of the guys brb
Quote from: Kris on April 06, 2006, 05:53:23 PM
what is the spacer for CJ??
cancel
inside the shock bushing...? looks like the ones on my bilsteins for the 12mm bolt
Hyena
KYOTA
looks like the small peice of tubing gets welded to the upper gusset then the shock slides onto it since its in single shear to take the stress off the bolt. Just like the factory rear shock mounts are basically
cheap sunglasses
Anyone figure this out for sure? I know on the FROR kit you have to fab up new shock mounts but perhaps Marlin has out-designed them?
'82 on 35's, not much else.
Kris
Still need a pic for the install.  I think you cut off the top shock mount and then weld the tube on the back side of the gusset.
I called Cj and cruzerdave  on there cells, no answer :thud:  so i reported this to moderation  so maybe someone from the shop will check it out
Here is the only picture I could find:
I will have to take some pictures today and then post them up later tonight. Someone from the office will see this post today and help out
Regards,
CruzrDave
Sorry for the delay. I took a pic of the kit on the formula toy this morning. I hope this helps
ok,  so the little spacer goes on the opposite  side of the gusset from the shock  :thumbs:
Kris
THANKS A LOT.  Now I see how it goes.  So you take the hole shock mont off and weld the gusset in the middle .  The tube will go on the opposite side if the gusset from the shock. :thumbs:
POWERSTROKEN
"Don't RAM it...STROKE it"
CruzrDave
$29 per axle. Our pic on the web only show 4 steering stop caps but you get 8 of them with the kit.
Here is an other pic of the kit on a FJ62 axle thats going under my FJ40.
Hyena
What if someone doesn't need the steering stop gussets?  Mine are already gusseted.  Could we get the kit without them for a little cheaper of a price?
CruzrDave
Quote from: Hyena on April 25, 2006, 09:32:47 PM
Of coarse. I'd need to crunch the numbers to see what the price difference would be. I'll post up the price.
are these listed on the website? couldn't find them but I am a little slowwww... :cheese:
abnormaltoy
Quote from: DirToyBoy on May 20, 2006, 03:55:18 PM
Right here, you'd think (I'd have thought anyway) they'd be on the axle page...but they're armor.
http://www.marlincrawler.com/htm/armor.htm
-- Winston Churchill
Travis Tritt (I know!)
cplux
when i rang up to order some of these knuckle gussets a few weeks back was told there was none in stock. Are they in stock yet??
CruzrDave
Yes we got our shipment last week. If you want the kit with out the steering stop caps it would cost $19.
