Knuckle Ball Gusset Kit
Started by CruzrDave, April 06, 2006, 03:06:27 PM
Dr.Maxwe001
I finished my ball gusset kit tonight I to didnt put the little spacer on the front of the axle I put it on the back :smack: get a hi temp grease it wont do that
[img]http://bo
Glad you got it all together :beerchug:
m4man_66
Figured Id post in this thread seeing as its the most recent one about this kit. I just recieved these guessets and I was under the belief that all 8 steering stops were included? I just dont see the sense in supplying plates for only the top face of the steering stops. I am going to be putting shock hoops on the frame as well and does anybody have a good rule of thumb for aligning upper and lower shock mounts from scratch? Such as castering the lower mounts back to align it to the springs path of movement, also would it be wise to install my shock mounts after i move my axle forward 3" or is it not important?
<MIKE>
yes wait till you move your axle before you weld your hoops on. or else it will be 3" off.
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
Quote from: m4man_66 on December 19, 2010, 03:00:49 PM
Aaron,
:welcome: to our support forums :wave: Yes, you should have received 8 total so we will get the missing 4 stops in the mail today, hopefully you're get them by Wednesday!
:beerchug: Happy Holidays,
m4man_66
Awesome, thanks guys. Im not new to this Toyota thing, I do my research and ask questions whenever possible. I am about to do ALOT of custom fabrication on my truck and am confident in my fab knowledge and welding skills. Its just the lack of experience "building trucks" and the neat tricks you learn from it along the way that is going to make this whole process harder.
The issues with this design have finally been corrected with our new Heavy Duty Knuckle Ball Gusset Kit!
Click here for details!! http://board.marlincrawler.com/index.php?topic=89022.0
Please post any questions or comments to the new thread! Thanks!
