Readers Rides
Started by HyDesertMutant, November 12, 2003, 04:36:56 PM
donkeykong
10 bucks an hour is alot better than 4.25, that is where I stzrted back in the day.  And I know there are plenty of guys here that started a hole lot lower than that.
Red_Runner
booger welds how could you call that toy junk i wish mine looked like that.
yotacrawler85
This is my junk, still in the process, but getting close.... I also have an 86 and an 87, one with a blown motor and the other with a blown tranny :rivers: got lots of work :beerchug:
85 cab on a 87 sas frame with 6 inch lift, 15x10 wheels, 34-10.50 swampers, all pro high steer, shock hoops, dual diff guards, in cab roll cage, rancho 5000s, all poly bushings remote diff breathers front and rear recievers, welded rear(4:30's) 22re
Bones
#63
86 4runner, 87 Xcab, 84 VIN plates  :biggthumpup:
-D44 front cut and turned, 5.38/ARB, Warns/CTM's, hi-steer, hydro assist, High Angle driveline, 44044 springs, 14" Bilstein 7100 w/remote and custom hanger and shackles
-8" rear, 5.29/spool, discs, All Pro 4", 14" Bilstien 5100
-Rebuilt 22RE w/$25 header (Turbo build up in the future)
-Dual cases w/4.0 rear
-37" MTR's w/Bobby Long Beadlocks
-Warn HS9500i and custom bumper
-Interior cage
-Powertank
-Kubota Orange paint  :moon:
Proud member of KNUCKLE HEAD OFF ROAD and the NUDE 4x4 CLUB  :bowdown:
Knuckle Head Off Road
mr4x42u
#64
bones you ride is coming out dayum nice!You need to turn the stereo down..I CAN BARLEY HEAR YOU!!!WHHAATAT?WHHHAAAT? 8)
85 yotacrawler..How do you like that auto?I don't see three sticks?
toyoda
If you don't know why I have a "D" in Toyoda you don't know Toyotas!!
http://my4x4tv.com/
jkimmel
Chevy Dana 60 front, cut down 2.5", springs are at stock Toy width. 5.86 gears, ARB, 35 spline outers.
Ford Dana 61 FF rear, 35spline Mosers, disc brake welded 5.86.
84runner
That is one sick ride jkimmel
84runner
82yotacrawler her did you get those rims with it 2 for $600?  Those puppys look nice
stone4x4
 :king:
GOD MADE DIRT AND DIRT DON'T HURT
stone4x4
 :king:
stone4x4
 :driving:
84runner
I know you get the girls in that thing Stone4x4
stone4x4
#73
i take it to shows have a 1st and 2nd place trophies in offroad class . Alot of girls want there pic tock with the ugly truck
but i'm ingaged!!!!
84 extra cab.  6 in lift.  35 inch mtr's.  5.29's.  rear detriot front lockright.
84runner
Engaged A.  Well that means you still get to have a bachelor party! :yupyup: :yupyup:
stone4x4
 :king:
stone4x4
 :king:
supercrawler
At the los coyote.
almost flip it.
Four Dice, almost rolled it into a tree a few feet back.
yota83
here is my 83..... its under the knife right now....
ill post some picks of the new mods as they go...
i cant remember!!!!!
CRAZY PEOPLE ARE NEET!!!!!
stone4x4
nice flex  who's springs  what  "
Looks like chevy's rear, but what up front?
dieseltoy
85runner, 96 2LT-2 turbodiesel w/3" mandrel exhaust, R151F trans/xfer (soon to have 4.7's) 87rear axle, Longfields, OTT Hysteer, elockers 4.56 F/R, usually run biodiesel
http://clean4x4.com
always keep your mind where they can't get at it.
yota83
Quote from: Hyena on February 16, 2004, 08:58:00 PM
rear is 63 chevy's with a double shackle setup stock toy to 2.5 yj front shackle
fronts are pro comp 2.5 Yj 51323's with a con fer front toy shackle
if youre thinking about running yj's up front i would recomend Rubicon Express Yj   RE1444's they are a reverse wraped military styile spring and are far better if you ask me... they run around $150 each
84runner
dieseltoy that is one staight runner :thumbs:
gferris5
yeah, dieseltoy, you need to post up on how you did that swap. We want details, yummy, yummy details.
dieseltoy
#87
Quote from: gferris5 on February 20, 2004, 06:46:45 PM
K here goes..
  Last may I took a srtraight original paint 85 runner and added parts I had been collecting for the previous year.
  As it sits, it took me a little over 6 mos in the garage.
  The motor is from a Japanese Land Cruzer, that was obtained from a local shop that imported it several years ago and never used (w/22K orig miles;-) Motor mounts matched the 22R block, but had to go with a Perma-Cool E-fan for clearance. V6 rad and perma-cool's larger 21" oil cooler for cooling.
  I built the 3" mandrel exhaust, in order to get rid of the restrictive cast elbow on the Toy turbo (even though the second gen diesel CT20 is totally different than the gas or early US diesel CT20's).
  No muffler, the turbo quiets it down pretty good, except for the "whistle". (You could swear you heard a Kenworth pull in the driveway.)
  The turbo trans/t-fer from a local yard, (got a spare of each just in case) and 23 spline MC 4.7 gears for the tcase.
  I ordered a heavier 3L diesel flywheel, Daikin extreme clutch, diesel "R series" bellhousing, 4WD oil pan, alt, reg, manifolds, PS pump, etc.etc from an Austrailian wrecking yard. The clucth is new, obviously, but I ordered it from them since they know the flywheel/motor. Turns out to be a Tundra clutch pattern.)
  87 rear housing, a pair of new Elockers from the dealer w/4.56 gears. Top speed on the hwy is about 70, so gearing is perfect. (Power band is all low RPM)
  A few tunnel mods, to make room for the carb style shifters.(Those Turbo shifters are hard to find. Thanks Marlin for your help with this, you probably don't remember)
  Hysteer required tossing the 4x4 oil pan and welding a 2WD oil pan and 22RE pan together. Even then the oil pan was still too deep, and had to go to OTT low profile 1.5" steering arms.
  Misc includes Teflon fuel lines (for 100% biodiesel-methanol eats rubber) and some standard stuff. Ford shock towers, OME frt springs (1.5" forward axle perch holes), Mazda/toy hybrid rears, longfields, 12" Bilsteins, FROR frt bump, tcase xmember, 95 seats, auto meter cluster, yada yada...
  This spring I want to add a soft top like the canback, (gonna try to build my own like the one on wildyoats.com)
40 gal rear tank (chop the tire carrier), HD rear bumper and some nerfs (gotta make some attempt to preserve this straight sheetmetal)
 You can see the progress at http://clean4x4.com
Some of the links still dont work..(our IT manager, and web development team are off on a world cruise with top supermodels, and I'm not sure when they will be back. Until then it's just me and a small dog, but we are doing the best we can.  :thumbs:
Ok, now i want a deisel, to many wires and hoses in the 22r.
OOPS
What it use to look like!!! 8)
Under going facelift!!!
