yes Goat they will bolt on to your stock carrierbut this isnt something you should try if you arent experienced in close tolerance mechanics,
yes you can, what do you have in the rear??
Werd, swap away. There is only one ratio that can require a ring shim, or some kinda adjustment and 5.29 aint it.
gonna be your daily driver ? i finally got lucky and founda elocker with a busted ring gear, swapped my 4.37's on it and i should get my harness tomorrowyou might consider running the welded in the rear till you find a good locker
Started by Jakesteads Toyota Pickup/4Runner Tech 1979-95
Started by Tombo-4Lo Project Research and Build-Ups
Started by myyota Engine
Started by zebracrawler Axle/Differential/Steering
Started by Wainiha Newbie Questions
