my proj truck..
Started by GoaT, February 06, 2006, 05:11:40 PM
GoaT
these are before pics i just got the truck i will post pics up of my build up...
snowshoebrue
cool what are you gonna do to it?
80crawleryota
cool can't wait to see it finished, much like mine
Cool, congrats :thumbs: .  When I paint mine I might hafta go with orange instead of red again.  Lookin good!
GoaT
basicly they installed an 85 drive train in it (carb), and lifted it and put some 35s on it. so what to do???
#1 cut fenders :) i plan to do a very clean job to the fenders i want to keep the rally look to it.
#2 get the motor in running condition and have it road savy... that includes the 5.29 gears
#3 clean up the int. hopfully i want to get a new dash or "dash cap", then dupli color. (the can rino liner stuff) the lower floor board and im avtuall plan on doing the int roof in "radiance paint" its a heat reflective pain that u spray the attic on a house to lower the heat inside of the attic.
#4 is steering. and im going to need a lil help on this one. id like to go with the stock set up just add a hyro asst onto it?? what is the common thing to do to the stearing to the trucks???
#5 is rock crawl ready time. i would like to go with new fields and some no slip in the axles.
and if anybody has any idead im open to suggjestions ther is much more im going to do to the truck just a lil much to list.. so what do yall think so far???
Shoyrtt
Quote from: GoaT on February 06, 2006, 08:45:08 PM
If you are going to rock crawl, think about the things that you will hang up on or damage. :idea:  As for steering, you should ditch the 1st gen push-pull steering box and install an 86+ IFS box and hysteer kit. It is a very common mod and with 35s you can probably save the $ and hold off buying a hydro assist. :twocents:
Another mod you should consider is a U-bolt flip kit. Again, low cost and will keep you from hanging up. :twocents:
As for axles, I would recommend going with Longfield. Bobby has a nice warranty and great customer service.  8)
Finally, Marlin's legendary dual transfer case set up and skid plate should be somewhere on your list. Take lots of pictures.  :)
http://www.sharetrails.org/
Quote from: Shoyrtt on February 06, 2006, 10:13:32 PM
X2 on all this.  As for cuttin the fenders I've yet to do mine so I'm still kinda scratching my head a little on it.  I was tellin a friend my plans the other day and he made a good suggestion.  I don't wanna just cut straight back in line with the headlight door like everybody does, but I wanna start straight there and gradually curve up so it looks smoother and more factory, and gives me that extra little clearance.  He suggested initially cutting straight back with my sawzall then doing the curve with something else more precise, I'm thinking small pneumatic cut off.  I'm also going to try rolling the fender under like the factory too for a cleaner look.  I'm gonna need extra clearance too cause I'm staying as low as possible and using rears up front, so my axle will be pushed 2" further forward.
GoaT
i just found thos long frields and i like that warranty + there $60 each cheaper then newfields. so cool... and isnt that hysteer kit $400 or so i thought i saw it the other day and didnt think it was for my truck. What is so bad about the push pull steering? with a hydro assist???
oh with the long fields... i believe the axles will keep up with the 35s right??? i have not herd of them being a weak link???
oh and i was also wanting to weld my shock to my axles with some tabs is that common is there a kit for it???
please what ever ideas yall have shoot them at me id appriciat it guys
GoaT
Quote from: kneedownnate on February 06, 2006, 11:00:30 PM
using rears up front??? what does that mean? and i have the same idea with cutting the fender u do. i might even get my buddie to flare out the fender i cut to keep it factory ralley style...
GoaT
Quote from: GoaT on February 07, 2006, 03:41:21 PM
k found the flip kit and found the new shock mounts also thanks
whiteman
Awsome truck man, I love 1st gen.   I just orderd the flip kit for my truck and got it installed, great investment.
Shoyrtt
Read my thread, or the many other buildups here. We basically build similar rigs to what you are looking for. ;)  http://board.marlincrawler.com/index.php?topic=18832.0
To your questions:
1. Yes, hysteer is for your truck;
2. Push pull is bad news. It will break with any hard wheeling and will never hold up to the stress of hydro;
3. Longfields, especially 30 splines, will be more than strong enough for 35s. Your weak link will be your hubs, so carry a spare;
4. Shocks tabs for the rear axle? There are many ways to mount them. I went with the / \ angle.
Quote from: GoaT on February 07, 2006, 03:44:06 PM
A lot of people take rear springs off a 2wd, mix and match springs however they want then put them on the front of the 4by.  The amount of lift varies depending on how you set up your springs, but 2 or 3" seems to be standard, and the ride is better.
GoaT
#17
Quote from: Shoyrtt on February 07, 2006, 05:31:12 PM
To your questions:
cool build up mang. that hyster is expensive and will be a long while befor im going to spend the money on that. i know it will be something i will need but i wont be doing any major crawling with it FOR NOW :)....  can u give a run down on the spline #s i know the more the better.. but what is stock??? and im assuming u cant mix #s. say stock #s and different then long fields????? sorry if that is a dumb question.
i plan on geting a set of MILE MARKER HUBS... any body have any expiriance with these? friends say the name is good... so what ever info is good 95$ a pair fyi....
oh ya why i figured out my shock mount ill just place them about where stock is i guess. i dont want to replace them there brand new.
GoaT
Quote from: kneedownnate on February 07, 2006, 07:14:08 PM
im sure there are lift spring on ther allready so i dont suppose ill be changing anything in that since.. right????
Shoyrtt
Quote from: GoaT on February 07, 2006, 08:42:25 PM
Splines on a stock front axle are 30 spline at the dif and 27 spline at the birf. Longfield's super axles are 30 spline all the way across.
I have heard Mile Marker and Warn hubs should be avoided. Pick up a spare set of stock Aisn hubs from your local yard. :)
furrballs95
nice truck that things gonna make a sweet rig :thumbs:
95 Toyota p/u 3.0 v6. Marlin SAS with 5"springs, 30 spline bobby longs, and a welded V6 third in a trussed 85 front axle. 529's front and rear, Marlin rear kit with 5" springs, lockrite rear locker,  36"  IROCKS on 15x10 black rock crawlers, custom front and rear bumpers,
CSAKing
nice i like it i wish i could find one like that to start working on
looking for a 80-85 not built toyota pickup in tenn, nc, sc, virginia can anyone help????
GoaT
kk time to start the madness. she is coming home tomarrow!!!!
CrazyYota
WE got the same bumpers except the roll bar. Mine is double! Sweet truck! LOVE THE First gens!! :beerchug:
hey Goat,  sorry i havent chimed in  i just realized your local :yikes:
burnyota  and swampy are right on top of you near Sanantonia,  im in arkansas
also  red is in Midland  and speeddemon  is in sanantonio too
if i was you i would get my gears to 5.29  and some sort of locker in the rear  befor i did anything else
I suggest that GoaT spend some quality time  :working: the  marlin site.  There is an amazing amount of information to be gained from just "window" shopping.  Plus, it's fun!
One thing you can learn from Marlin is that bobbing the bed make way more difference that cutting of the lower portion.  You will notice that Marlin didn't bob his bed for a long time and when I spoke with him  :phone: once he said he couldn't belive how long it took him to finally do the mod.  He loved it!
Longfield axles are definately the best way to go for axles.
Quote from: 79Coyotefrg on February 20, 2006, 12:27:38 PM
stick with aisin hubs :yesnod:
There is only one minor problem with stock aisin hubs, they are large enough that some wheels won't fit.  My dad's wheel from his Blazer wouldn't clear my hub, but my buddy just swapped tires with him and the Warn Premiums are small enough that they worked.
It is still not enough reason to consider not running the stockers.
GoaT
Quote from: blackdiamond on February 20, 2006, 12:42:38 PM
whats wrong with mile marker hubs???
