looks good what size tire and lift do you have
I must have the homer simpson punching bag behind you....it's non-negotiable!!!
Sure does Hey GoaT we need to go wheelin man
Kind of whatg I was thinkin I used to have one of those homers too, until my roomate shot him with a bb gun now he's a wall decoration.Sometimes, at night, I can still hear him... "doh! Ow!! Doh!, Quit hitting me! "
Everybody could use a helping hand. I wish there were more Janets in the world. (I wish there were more Janets in my area, that's for sure.)
Well, I know when or if you front axle is tweaked, that driver-side axle can be a pain! I had the same problem, but I just turned to pinion flange and was able to get it done. I had to lift up on it a little and scream and holler and it went in. Just work it a little. I wouldn't believe that you have twisted some splines on the shaft (which happened to a friend, and it was hell getting it out!)?As far as the main shifter hitting the transfer case shifter, I know some guys that have taken their main shifter off and used a huge pipe and vise to bend it back a bit to keep that annoying "hitting and popping" out of gear thing under control.Hope that helps a bit!I believe Minisimp had to do the same thing with his main shifter, so maybe he has some advice.
Lookin good man . That's pretty close to what I was planning on doing, angle up a little for that little bit extra clearance. Good job!edit: it'd look pretty cool if you took the lower tube on the bumper and angled it up and connect it right at the end of the top tube. Does that make sense?
this pic of my friend janet makes me feel funny....is this normal???
what are u doing to it (ur truck)
Started by rEdnECkwHeE1eR General 4WD Discussion
Started by 95TacoTruck General 4WD Discussion
Started by rEdnECkwHeE1eR Project Research and Build-Ups
Started by Viper4chris General 4WD Discussion
Started by wa4x4 Parts For Sale
