another 89 4runner on 60's
Started by alwaysbroken, January 15, 2006, 09:13:11 PM
alwaysbroken
Hey new guy here. First toy i built still have lots of work to be done on it..
89 4 Runner, 3.0, 5spd, 2.28 crawl box, 4-1 atlas, prorock 60 up front, crd60 out back, on 37" mtr's
alwaysbroken
crawlerdan
WTF!!?? we need specs, and a reason why your runnin a drivers drop axle :thumbs:
alwaysbroken
 front Prorock 60 with 35spline inners and outers, Rear tera 60 35spline, atlas case with 4:1 crawler box with 2.28..
I rolled my jeep and i decided to build a toy, thats why i have a drivers side drop, and a atlas.
motorider228
HOLY SHIRT!!!!!!!!!! my favorite on the website now. Are you running a drivers side drop because of that atlas?
crawlerdan
Quote from: alwaysbroken on January 15, 2006, 09:24:15 PM
:yesnod:  :dunno: thats cool man, almost as clean as mine....ok so it is, good work
alwaysbroken
Because of my front axle. I had to make the axle work with the runner.(I had the axle before i owned the truck)
alwaysbroken
i'll get some action shots this weekend.. Going out to do a poker run at Truck Haven.
brakeman
hey how much lift do you have on that 4 runner, always broken. I have a 3'' suspension and 3' lift but it doesnt look like 6'' lift. I dont know do you have any suggestions how i can get more lift for tire clearance i need to fit 35's with some space.
alwaysbroken
Quote from: brakeman on January 15, 2006, 09:31:50 PM
I'm running about 7" of lift with very little finder trimming in the rear.. When i four link the rear i will lower it 2" and cut more body.
KWP
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
Loosekannon
Quote from: alwaysbroken on January 15, 2006, 09:31:28 PM
I'll keep an eye out for you, I'll be out there too :beerchug:  Your 4runner looks good. :thumbs:
brakeman
i have a 3'' suspension and 3'' body do you think 35 boggers will fit comfotably? If i put a shackle lift on do you think that will give me enough clearance? What size tires do you have on your 4runner?
tyler
BoMXtreme
Quote from: brakeman on January 18, 2006, 10:40:10 PM
tyler
Your probably good, but your front tires might rub a little on the inside corner of your fenders.
Looking for 35s in SLO later summer time, like august.  Swapping Tires??
alwaysbroken
wa4x4
Clean work man! I like it! That is now my second favorite on this site...exo and it will be my favorite.
crawlerdan
alwaysbroken
gotrocks
oh wow, I'm in love, I hope my runner looks that nice someday, very clean looking rig, 1 turtle point for you, and if I don't mind could you give us some more up close shots of that supsension, I just can't get over how nice it is.  It looks like you are running a TJ style front suspension, is it the Rubicon express kit?  Since you said you rolled your jeep I'm assuming that you just grafted the front suspension off of your jeep and placed it under the runner.
alwaysbroken
Quote from: gotrocks on January 27, 2006, 06:27:47 PM
Yep thats what exactly what i did..
motorider228
i still cant get over how nice your rig is. yours and crawlerdans are my favorites on this site. Also how hard was it getting the jeep suspension to work well on your yota?
gotrocks
I'm thinking of converting my front suspension soon to a linked setup and I will be copying the rockkrawlers setup I had on my Jeep.  Seeing yours makes me wish I would've kept my axles somtimes, I had a Dynatrac 44 front and HP60 rear with arb's and 5.13 gears.  Again Very nice 4runner.  Still would love to see some more pictures of it. ARe you gointo link the rear soon or is it already and I just missed it?
alwaysbroken
The hardest part was aligning up the axle, other than that it was easy switch to everything just a couple of tabs for the arms, and the panhard bar.
Also A new t-100 oil pan to clear everything. It's going to be linked in the rear  by summer time.
gotrocks
keep us posted on that, do you use your Airshox much on the road.  I've heard they are not recommended because they can over heat to fast travel they experience from street driving.  Just wondering what you thought about them
alwaysbroken
The air shocks are not bad on the road when i link the rear i will have to run a swaybar, I take my runner out to the local
sanddunes( Glamis, Domont, Pismo) and they done great. Ready for a set on the rear :thumbs:
hammerdown
i noticed your runner has a v6 emblem on it, how do you like the 3.0? likes/dislikes?
Country Boy Can Survive
alwaysbroken
 Under power motor but it starts everytime :clap2:   I'm keeping the 3.0 untill it dies, Working on getting my hands on a LS1 vette motor :yikes:
gotrocks
the reason I'm asking about how they air shock work is that I've been told that I can't use them if the rig is going to be used as a DD or driven at any speed because of safety and the shocks start to loose their rebound speed if they are used at faster speeds.  I don't see why they wouldn't work, like you said you've used them at glamis and they worked fine for you.  If I run them I want to have a onboard nitro tank so that I can remote control them from inside the cab.  Have you ever thought of doing that to your rig?
alwaysbroken
I thought about carring another tank but no room, i have a co2 tank so if i have to i can put air into them until
i can use nitrogen. They have been on there 4 months, 5 wheeling trips and no problems.
