Author Topic: Funny Sound  (Read 2288 times)
1Bad4Runner
  • Turtle Points: 45
  • Male Posts: 609
  • Member since Feb '05
Funny Sound
« on: Jan 13, 2006, 01:28:51 PM »
Right after I lifted my truck I started to get a vibration in the back of my truck, I thought it was the U-joint so I looked under and they were fine. :headscratch:
I left it for another week because the garage was taken up by my fathers truck and the vibration has gotten a little worse and sounds kind of like a rattling when you let off of the gas. I was thinking maybe the output bearing in the t-case, anyone have any ideas? :help:
lilbuddy
  • Dried Fruit Warrior
  • Turtle Points: -234
  • Male Posts: 5,720
  • Member since Aug '04
  • Hella....
Re: Funny Sound
« Reply #1 on: Jan 13, 2006, 04:11:02 PM »
5 bucks says the Pinion Nut is loose. Either that or you have a broken ring gear. I was coming back from the Con and GENO was in front of me and I could hear it while we were driving, stopped, tightend it. Got back to Chico, he undid the third and found out that the ring gear had some broken teeth off of it.
RIP Kyota.... you are the man
GET IT!!!
1Bad4Runner [OP]
  • Turtle Points: 45
  • Male Posts: 609
Re: Funny Sound
« Reply #2 on: Jan 13, 2006, 05:00:42 PM »
its never been wheeled before though :screwy: But I do spin the tires sometimes. :headscratch:
I'll have to check the oil and see if there are metal chunks.
Thanks Lilbuddy! :beerchug:
KWP
  • Male Posts: 878
  • Member since Jul '04
  • Ghost Hunter
    • East Central Oklahoma Paranormal Society
Re: Funny Sound
« Reply #3 on: Jan 13, 2006, 05:26:18 PM »
 I was thinking U joint. I had the same problem in my 4runner at the tcase end. My mistake was I didn't check it in time and on my way to work one day the U joint came apart going down the highway at about 70. Not a very pleasant experience :scared:
88 Toyota truck ( Under Construction ) Dana 60's front and rear 5.38's, welded diffs, 3inch Downey rears up front,one link rear with aerostar coils rolling on 39.5x16.50/17 Pittbull Rockers and 17x9 Pro Comp extreme alloys.http://board.marlincrawler.com/index.php?topic=40816.0
1Bad4Runner [OP]
  • Turtle Points: 45
  • Male Posts: 609
Re: Funny Sound
« Reply #4 on: Jan 13, 2006, 06:30:24 PM »
Ouch! Thats sucks. :thumbdown:
I already checked the U-joint, I think Lilbuddy might be right, it does sound like a kind of grinding noise. I hope thats what it is since I am replacing the gears this week. :crossed:
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: Funny Sound
« Reply #5 on: Jan 14, 2006, 03:10:38 PM »
I would agree with this, I had this happen to me a long time ago. When you are under acceleration the load will force the pinion up and off the carrier, when you are decelerating it will be driven into the carrier creating a low growling noise and a vibration.
1Bad4Runner [OP]
  • Turtle Points: 45
  • Male Posts: 609
Re: Funny Sound
« Reply #6 on: Jan 14, 2006, 06:04:29 PM »
The pinion nut has never been off of the truck before, I looked at it and the lock is still in place and it all seems tight. Would I be able to tell it is loose? The pinion turns about 1/2" back and forth, I though this seemed back, but I talked to some people and they said for an older truck that is alright. :headscratch: What do you guys think? :dunno:
KWP
  • Male Posts: 878
  • Ghost Hunter
Re: Funny Sound
« Reply #7 on: Jan 14, 2006, 06:18:17 PM »
That sounds about right. It will have some movement.
1Bad4Runner [OP]
  • Turtle Points: 45
  • Male Posts: 609
Re: Funny Sound
« Reply #8 on: Jan 15, 2006, 05:23:05 AM »
Ok, well... I guess I will find out soon anyways, since my gear install kits should be in on Tuesday and then I will be adding some 5.29's to the truck and hope it sounds alright. :yesnod:
Thanks for the help, I'll update if it goes away or stays.
Last post May 16, 2004, 03:49:21 PM
by 79coyotefrg
Last post May 29, 2006, 01:23:14 AM
by eightyfive
Last post Jul 02, 2007, 04:29:05 PM
by Twisted_Fenders
Last post Sep 22, 2007, 10:28:15 AM
by Plekto
Last post Nov 06, 2007, 08:08:02 PM
by skipnrocks
