Author Topic: 22 re codes?? what do they mean?  (Read 2516 times)
dov'd85
  • Turtle Points: -470
  • Male Posts: 348
  • Member since Dec '05
« on: Dec 14, 2005, 04:09:23 PM »
checked my computer and it gave me 2 blinks 4blinks 7 blinks and 8 blinks what do these mean and what sensors need to be replaced?
85 long bed: 30 spline long, hydro assist, hysteer, 223.1 twin sticks, 39.5 iroks, rear disk,
http://board.marlincrawler.com/index.php?topic=28696.msg344178#msg344178
Uncle Jesse
  • Turtle Points: 21
  • Male Posts: 375
  • Member since Sep '04
Re: 22 re codes?? what do they mean?
« Reply #1 on: Dec 14, 2005, 05:04:33 PM »
You need to pay attention to the blinks, and the spaces between the blinks.  Two blinks, short space, and four blinks  would be a 24 code.  Then, if there is a long space, it means the start of the next codes or the start of repeating the first code.
http://www.off-road.com/toyota/tech/codes/
dov'd85 [OP]
  • Male Posts: 348
« Reply #2 on: Dec 20, 2005, 04:28:50 PM »
the codes are 2 seconds apart. they are 4 seperate codes...
Uncle Jesse
  • Turtle Points: 21
  • Male Posts: 375
« Reply #3 on: Dec 20, 2005, 04:53:26 PM »
I don't believe that there are any numbered codes below 11
dov'd85 [OP]
  • Male Posts: 348
« Reply #4 on: Dec 21, 2005, 01:51:16 PM »
in the book it tells me codes 2 4 7 8. are 2 blinks airflow meter siglan    4 blinks  waterpump thermo sensor    7 blinks throttle position sensor signal
8 blinks intake thermo signal
then it gives a list of trouble area's i want to no what sensors would most like be the ones for thes codes....
were would i go to get a thermo sensor and what is the intake thermo signal? and the air flow meter signal?
thanks
james
Uncle Jesse
  • Turtle Points: 21
  • Male Posts: 375
« Reply #5 on: Dec 21, 2005, 03:51:50 PM »
The intake air temp sensor is inside of the air flow meter.  The water temp sensor is on the lower intake, approximately below the thermostat housing.
dov'd85 [OP]
  • Male Posts: 348
« Reply #6 on: Dec 22, 2005, 10:02:03 AM »
what is the sensor right before the thermostat?
Last post Apr 20, 2006, 01:22:22 AM
by crapyota
Last post Mar 26, 2007, 06:36:07 PM
by 86 4runner
Last post May 16, 2007, 10:01:45 PM
by toyrunner87
Last post Aug 09, 2007, 06:17:59 PM
by *** YELLER ***
Last post Jan 26, 2008, 12:39:40 PM
by 79coyotefrg
