Author Topic: few tranny questions L43 and W58  (Read 1326 times)
skid
  • Turtle Points: 144
  • Male Posts: 295
  • Member since Oct '04
« on: Dec 12, 2005, 06:50:58 AM »
Right now I have a failing L43.   It's pops out of reverse, finds a lot of neutrals and sometimes locks up when shifting.  Can the shifter/side cover be removed while in the truck and will a 2wd counterpart interchange with that cover.
I also have a good 2wd w58 out of a supra.  I'm thinking swapping in  4wd output parts.  With the 3.2:1? first gear I would change the diffs to 5.29 from the stock 4:.37's.  Has anyone ran a similar setup and was the transmission gearing a problem when wheeling?
« Last Edit: Dec 12, 2005, 07:53:34 AM by skid »
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
  • Turtle Points: 1128
  • Male Posts: 9,757
Re: few tranny questions L43 and W58
« Reply #1 on: Dec 12, 2005, 05:14:21 PM »
I talked to marlin about it a while back, and if I remember right you're gonna need the tail end of a w series 4by tranny to make it work, and a 4cyl w series bellhousing.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Dec 12, 2005, 05:20:22 PM »
and that 3.2 1st gear is going to be a little better than taing off in 2nd gear,   where are you,  i have a good 43  i'll sell cheap,  $50
Last post May 21, 2008, 01:30:05 AM
by digitaldevil
Last post Apr 14, 2012, 09:09:08 AM
by El Jefe
Last post Mar 09, 2020, 02:44:29 PM
by T-Revv
Last post Apr 21, 2021, 12:00:50 PM
by Cheesemaker
Last post Apr 05, 2023, 06:12:48 PM
by onwheels
