Author Topic: sure its been covered, but search didn't trun up anything. Third member ???  (Read 2631 times)
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
1. Will a v6 3rd fit into a 4cyl housing without clearancing?  what needs to be clearanced if it doesn't?
2. are front and rear 3rds interchangable, or are they different?
              -Ronald Reagan
yotacrawler4
  • Turtle Points: -167
  • Male Posts: 137
  • Member since Mar '05
  • "Just hold it to the floor"
yes third members (8'') 79-95 are all interchangable and no u dont have to do any clearancing, i just did a V6 third and a high pinion in my truck :turtle:  :beerchug:
86' yota, extra cab, duals, HP frnt with detroit 4.88s, V6 rear with detroit 4.88s, bobby super set, driveline tech dl's, neat lil upgrades on the way can someone say 4link and dovetail front...
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
swap away there Blackdog,  i just installed a 4.37 4cyl ring gear on my elocker,
had to make a custom sleeve,  and i need to refit some things befor installation but i think it'll work great
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
toyo487
  • Turtle Points: 162
  • Male Posts: 493
  • Member since Oct '05
  • Living life in Gods county
I just put V6 thirds in my 4cyl,  the front and rear went with ease.  The V6 thrids that I found had the 4.88's and  I did no clearancing to fit.  Good luck
1986 Toyota 4Runner 22re 5spd transmission and dual transfer cases (4.7’s in the rear). E-lockers front and rear.
2005 GMC Sierra diesel, compound turbo setup to pull.
   God gave all people talents but the only one who can find them is you.
Prismo
  • Online The 1K Club
  • Turtle Points: 8323
  • Member since Oct '03
  • Living in the green house
I have a turbo truck third member in the back of the runner, Swaps right in.
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
i'm gonna put a V6 4.88 3rd member in my front axle.  on test fitting it i found that it wouldn't go in.  i figured out my problem, the flange for the 3rd member is double thick, and while the top layer of the bottom notch was cut out, it was barely cut on the bottom layer.  i took my angle grinder to it and all is well
Prismo
What year axle Kyle?
kyle_22r
  • Male Posts: 1,233
  • yellow beast
79.  i think it was just a factory screwup, no big deal.
Last post Feb 03, 2005, 03:08:27 PM
by 40man
SEARCH!!!!!
Last post Sep 01, 2013, 07:26:31 PM
by Rocksurfer
Last post Dec 31, 2005, 07:11:52 PM
by Lady Di
Last post Apr 09, 2012, 10:48:55 PM
by *** YELLER ***
Last post Jan 05, 2023, 09:43:14 AM
by TacoEspecial
