...why buy when you can build?
I purchased an enginbldr rebuild kit and some of the components were ok. I got the street cam and it really didn't help out much at all, (just a little low end torque) I'd go with the bigger cam. STAY AWAY FROM THERE STEEL TIMMING CHAIN KIT. I used two of these is two different toyota's and had problems with both. I ended up replacing them with a differet brand. The chain would actually hit the bolts causing my engine to sound like a deisel, after replacing his timming chain kit with a PCI kit. (I purchase this kit at a local machine shop for 55 dollars.) The noise went away. His prices are decent but check your local machine shop they may be able to sell you all the stuff you need for the same price. Anyway that is just my good luck with your engine build
I liive near boulder. Sounds like we are making the same swap. Except I am going from a 8522r to a 85 22re, but they should be VERY much the same. $650 is the best I have seen, and I have been looking, but I have decied to rebuild mine so I know whats in it.From that thread, it sounded like the LC cam made a bigger difference than anything else, so thats the route that I am going to go. Should I get new pistons too? THe ones I have are fine, a little dirty ontop, but they are fine. Would I get any more power if i got a different piston?HOW ELSE CAN YOU GET POWER FROM A 22RE?thanksPZQuoteGet your head done awesome, i would het a TRD stage two for 160 from toyota awesome cams, w\then get lc oversized valves, then get ARP rods and bolts for the bottom end, then Balance the whole bottom end thats what is key on yotas, but if you get all the head done awesome, like port polishing, the valve and bigger cam then thats where you get power form these , its all in the head
i'll tell you what you don't need to do on a non-turbo engine...you won't need aftermarket rods(stock are forged and very stout), main studs, head studs, etc.the best investment you can make on one of these engines is good port work and a good exhaust. as for the exhaust, if it's an '85-95 engine it's already set up like a good tri-y header. the '84-down engines had a junk exhaust manifold though, so those are best replaced with a header. however in '85 toyota started using a manifold that'll actually improve performance -- just get your pipe where the 2 join up replaced with a 2" or 2.25" pipe all the way back.
Started by awhotrods Engine
Started by Volcom Engine
Started by 91 super yoda Project Research and Build-Ups
Started by Rocktoy2 Toyota Pickup/4Runner Tech 1979-95
Started by THK Matt Toyota Pickup/4Runner Tech 1979-95
