Author Topic: a340h to '85 double cardin joint  (Read 1368 times)
hugh jeffner
  • Turtle Points: 152
« on: Oct 17, 2005, 08:10:47 PM »
here's what i got, a '90 runner with the a340h trans/tcase, and i have done an SAS and need the front driveshaft to hook up.  i have a flange from a non chain drive tcase, but it seems like the spines are different than what i have.....any ideas.....here's a pic of what i have.
CruzrDave
  • Turtle Points: 441
  • Male Posts: 4,631
Re: a340h to '85 double cardin joint
« Reply #1 on: Oct 17, 2005, 09:29:02 PM »
Ok, 1979 to 1995 Toyota's have 6 different style bolt patterens. 5 different flanges for the gear driven case's, 2 different flanges for chains case's behind 5spd's, and 3 for auto t-cases. The chain 5spd and auto's cases have 30 spline flanges while the gear drive has 27 spline. The auto spline is also more of a square shape. Because the front auto flange is not round its not the best for "re-drilling". We have in the past sloted the holes to use a CV. The best way is to use a rear Auto T-case flange. It has the correct splines and is round so re-drilling the bolt pattern is a cake walk or a Tacoma CV will bolt right to it. The flange you have pictured is a V6 CV joint pattern. If you clearence the V6 CV it will have the proper movement.
Taking back America, one part at a time! :madeinusa:
hugh jeffner [OP]
« Reply #2 on: Oct 18, 2005, 07:32:27 AM »
man i sure hope you had to look in a book to find out those numbers, if not, i've got one word for you...........freetime..............just kidding of course, thanks for the info, looks like i'm off to try and find a rear flange from an auto, as i have a square driveshaft, with the older double cardin joint, that i really want to use.  thanks again man.
Last post Jun 13, 2002, 03:19:21 AM
by Brandon
Last post May 24, 2005, 02:05:41 AM
by WHITE_TRASH
Last post Nov 30, 2007, 07:38:11 PM
by Dave J.
Last post Feb 24, 2012, 12:52:27 AM
by Danny de Bont
Last post Aug 15, 2013, 03:56:30 PM
by emsvitil
