I was just curious if it is possible to have a double cardon joint made up using a joint at both ends?
Sounds overkill but it was just a thought, seems like it would eliminate any vibes at all, reguardless of pinion angle.
I thing this is done with short short wheelbase rigs like Jeeps etc...
Seems like it would prolong the life of the joints since your cutting the operating angles twice, instead of once, and the cv seems much stronger than a single u-joint at the pinion end of the shaft.
