installing chevy 63" springs
Started by zeke jr., October 16, 2005, 02:33:20 PM
zeke jr.
yesterday i went to pick and pull and i brought back a set of 63" rear springs fro my 4runner. i was wondering if any of you guys/gals could help me out. i need to know how much to move the spring hangers i am told i need to move the farthest rear hanger back 4" and the other im not sure in fact i dont even know if the first measurement was correct any information you guys could provide would be awesome. in addition i was wondering what you guys would reccomend about keeping the overload spring or to find an add-a-leaf for it? thnx alot.
-zeke jr.
always remember a crowded elevator smells different to a midget.
"I sincerely believe that banking establishments are more dangerous than standing armies, and that the principle of spending money to be paid by posterity, under the name of funding, is but swindling futurity on a large scale."
"The end of democracy and the defeat of the American Revolution will occur when government falls into the hands of lending institutions and moneyed incorporations."
dentedfender
i think you move the front spring hanger forward 11 inches and the rear 4 or so the shackle is straight up and down with no weight on the springs.  The was i figured how much to move mine for my f-150s was to mark your old center line then put a peice of string on the centerline with weight on the botom of the string and then put your new springs up there makeing sure your center line matches up and mark the point where the front of the spring tuches the frame.
85 4runner rears up front f-150s out back dual 2.28 cases 22re, rear discs, 5.29s, locked f/r, 38s....... list goes on and on
Tweeked89
search on Pirate, yes its 11" foward, and extend you shackles. goto the toyota section, its on the first page
W.H.O.R.E. founding member
-My G-Ride-[/b]
89 Ex-cab Toyota, V6, Locked Dana 60s, new 39" IROKS, kinda built kinda not
4runner freak
Finally got my '85 4runner!
Let the buildup begin!
Working on DUAL-TRANNYS
http://www.pirate4x4.com/forum/showthread.php?t=862345
zeke jr.
sweet thnx bros. well slowly but surely the rig will be completed. well correction there are never completed always something more you want but being a full time student and only having 1 car i have to wait until the next major brake to get all the neccisary mods.
-zeke jr.
S-10 Stewy
Zeke, those springs will flex mucho for you! :thumbs:   I have them on the rear of my S-10 and they work well.  I took the overloads off although I don't know that I needed to.  I have heard from the pirate forum that if you constantly arch the springs in a negative manner, they will bend near the eyes.  I have twisted mine up to the gills and have noticed that they are slightly tweaked.  Bump stops ?????   I probably never will, they are cheap enough that I will just replace them when they get to bad. :beerchug:
Stewy
It's built Chevy tough with Toyota stuff!
scyota
Will putting the 63" springs on an 84' pickup move the axle at all? if so, in what direction. this is for a friend with a pickup.
1993 4Runner SAS - SOLD
'01.5 Audi S4 2.7TT Stage 3
It matters were you mount the hangers.  If you mount the hangers 11 inches forward of the stock hangers then the axle won't be moved.  anything other then 11 inches and the axle will be moved.
scyota
Shamb
If i was gonna re-do my 63's i'd hang the shackle first and adjust the springs accordingly for maximum rear articulation.
Tweeked89
Quote from: Shamb on October 18, 2005, 09:48:39 PM
Thats kinda how your suppose to setup your suspension (leaf springs)
-My G-Ride-[/b]
Shamb
Quotehow your suppose to
Unfortunantly when your a newb with limited info you try many different things until one finally works
:hammer:
mxpro_156
Im doing Chevies in my '84 right now and i moved my front hanger forward 11'' and my rear back about 4 1/4'' with 6 in shackles i probably should have only moved them 4'' though. Good luck post some pics when ur done.
rude86
can anyone tell me what the 63 inch springs are off originally so i can find some. some one told me that they were off a chevy Z-71.
member of team marlin crawler
Toyminator
Quote from: rude86 on December 11, 2005, 04:52:06 PM
Did you read the FAQ link posted above? It's the very first question!
Quote
What year and vehicle do you get the springs from?
The correct years are 1988-1998 1/2 ton Chevy or GMC truck. Don't listen to anyone otherwise. And don't worry about the front suspension it does not matter. You only need the rear springs. Those are the only
years you can get 63 inchers.
