Kiyul4130s rig
Started by kiyul4130, October 09, 2005, 09:09:33 PM
kiyul4130
Quote from: Hyena on March 05, 2007, 01:13:11 PM
my work makes that plate for $125 with the ends.  maybe a little less for just the plate.
ah sweet. is there any way we could work something out?
-kiyul-
ECV 7-11
KYOTA FOREVER
i don't know, i don't have any say in the price or anything.  i will see what i can do though.
kiyul4130
Quote from: Hyena on March 05, 2007, 08:08:29 PM
alright cool. let me know when you can. im strapped for cash but ill see what i can do. i got all sorts of stuff to start working on in the next 2 weeks. i hate $$$
-kiyul-
ECV 7-11
KYOTA FOREVER
KYOTA
Quote from: kiyul4130 on March 02, 2007, 04:49:49 AM
screwin around on paint. not sure if i like it or not........        ?????
YEAH!! time to put that thing on a diet  :greengrin:
Ramrod
rick(brads boss) says there $125 for the full kit or $50 for just the center plate(what you need)  definitly a good deal but dont buy the whole thing because there not a really strong design how he builds them
Ramrod
I put some pics of it in my buildup page.  One thing to think about with those type of crossmembers is that there is alot more vibration at idle but it is also alot more solid.
kiyul4130
#156
Quote from: TEAM RAMROD on March 06, 2007, 10:12:21 PM
should i just buy the plate and make my own cross member to the plate?
edit: is the plate 3/8 or 1/4
edit again!! i forgot. im going to be running the clocked adapter. is there anyway i can still use that one? or will i just have to bolt it up to the clocked adapter as is and mod it that way to fit?
-kiyul-
ECV 7-11
KYOTA FOREVER
Reynolds
What did you want to know about the bed bob Kyle?
-Brian
Ramrod
the plate is 3/8 and the center section alone is great and all you'll need. nothing else will actually work with your clocked adapter.  Let me know if you want some better pics of mine.
kiyul4130
#159
Quote from: TEAM RAMROD on March 07, 2007, 04:17:32 PM
alright cool. just some of them mounting to either side of the frame. the other ones is good though. ya if i got one through brad that would be way cool. so i guess it will just sit on the clocked adapter then id have to make my own tube running from it to the frame rails. im thinking ( 1 1/2") square maybe? im also thinking i could purchase the end peices from front range. the hard rubber bushings
http://frontrangeoffroadfab.com/nfoscomm/catalog/images/transfer_case/Taco-xmem-033---2.jpg
heres the main page
http://frontrangeoffroadfab.com/nfoscomm/catalog/product_info.php?products_id=29&osCsid=842c6d78d5f70210eafe29ee8be29c64
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
Quote from: generalee7 on March 07, 2007, 04:06:35 PM
i just had a question about the rear part of the bed and how it mounts to the very end of the frame. so do you end up just bobbing that all out and your only left using the mounts by the end of the rear fender wells? cause the tail gate will be so close. i know its easy but it threw my off looking under my truck today.
-kiyul-
ECV 7-11
KYOTA FOREVER
Ramrod
the mounts to the frame are super simple yet super strong.  I had some bushings that trail gear sent me for some reason for there rear springs that pressed in perfectly in to some 1.75" .120 wall round that we had left over from bending that I welded to the notched tube going to the main transfercase plate then on the frame I welded a 3x7" plate to the frame with 2 plates coming off of it to put the bolt through.  I put a 3/4" in there but am using a 5/8" bolt so its easier to put together but make sure that you can still get the mount back on once u pull it off for final welding because mine is almost impossible without lowering the tranny down like 4"
kiyul4130
so i decided i really need to start working on this lame truck cause im running out of time. so today i got started on clearing the bed and tonight im going to work on cutting out the bumper and getting some of it welded together. sorry folks,  ::) no bed bob yet. maybe after hammers but for now im keeping it. ill post up more later tonight or tomorrow of what i get done.
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
i actually was able to bang out most of the dented parts on the passenger side rear panel and all the other really dented stuff was low enough to get cut off. the drivers side was one big dent but no scratches and that popped right out. so that was cool.
-kiyul-
ECV 7-11
KYOTA FOREVER
Rockcrawlintoy
u should have the bed sprayed from the tail lights down around the bottom
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Ramrod
kiyul4130
#166
alright so im in a bind!  :maddest: im really trying to figure this out by tomorrow (wednesday) or thursday, NO LATER THAN FRIDAY. so im a little strapped on cash and have been wanting duals for the last 2 1/2 years. i deffinetally need a little more gearing for this hammers trip. so heres the deal.
Marlins out of the v6plate and i deffinetally need that no matter what before i got to hammers. heres the catch why.
rockcrawlintoy has came across some great points on what i should do:
1st. we started punching $ numbers and gearing numbers. i thought i could just order everything from here and get the v6 plate from inchworm. the total outcome of gearing equals out to 97:1. stock duals in my truck. total is $909 (ship not includ) still leaves me with some cash for cross member stuff and to make a driveline.
2nd. we thought (rockcrawlintoy) get the v6 plate, 4.7s from marlin and the 23spline input gear. the gearing here equals out to 88:1 (not very much less) this total comes to $954 i think (w/o shipping)
3rd. my idea is to call marlin and see how much all the dual ulti stuff would be minus the v6 plate. then order that from inchworm but i would be SOL for a crossmember and it would be sketch getting in a rear driveline in time. which ever way it turned out. (HEY my birthday is on friday so maybe thats a good thing!???) but i think it could get done. the dual ulti stuff is $1373. so minus the v6 plate looks to be $1023.
sorry for the long post. im just trying to deside this week and make an order already!!!!!!!!!! its been so long since ive wanted duals but as moneys kinda tight im tossing up 3 ideas. everyone lean me towards something im ready to make an order!!!!!!!!!!!!!  :mad:  :willynilly:  :slap:
-kiyul-
ECV 7-11
KYOTA FOREVER
lilbuddy
Make a poll somewhere (general 4x4 probably), copy and paste all the ideas then put that as the decisions you can use for the poll. Then post the link in your thread.
I dont know its just an idea.
I say get the 4.7s, run one case and get the second case in later. Cheaper and easier.
Sorry I didnt call you back today
RIP Kyota.... you are the man
GET IT!!!
kiyul4130
no worries. ya i do have both cases. so im kinda thinking just throw in the other case this summer????
-kiyul-
ECV 7-11
KYOTA FOREVER
lilbuddy
Quote from: kiyul4130 on April 03, 2007, 11:36:39 PM
Exactly.
GET IT!!!
Ramrod
either way I really dont care right now but you better do something fast.  I saw stock duals, but whateva
Rockcrawlintoy
Quote from: kiyul4130 on April 03, 2007, 11:30:38 PM
u dont need the 23 spline input gear if u get the 23 spline 4.7 gears dude
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
kiyul4130
would 4hi change with a single case and 4.7s?
-kiyul-
ECV 7-11
KYOTA FOREVER
inmyownsummerami
Quote from: kiyul4130 on April 04, 2007, 12:09:09 PM
Nope only low range. Hi range(1:1) can not be changed.
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
kiyul4130
truck parts in the mail are sweet. got my v6 adapter plate and 23 spline input gear today. duals SOOOOOON!
-kiyul-
ECV 7-11
KYOTA FOREVER
Geno
Quote from: kiyul4130 on April 10, 2007, 12:11:48 PM
Ahh, very nice.
OFRD_GRL – as much as i appreciate strip clubs, i could never date a chic. they are all flopin crazy.
kiyul4130
seriously. its about freakin time. they are chris duals but he said i could run them till he needs them back and im sure ill have mine setup and ready to swap in when that time comes since i have cash left over and a tax return coming to.  where/what have you been up to lately?
-kiyul-
ECV 7-11
KYOTA FOREVER
Geno
#177
I have been swamped with work :(  Just now looking to start on my 4runner again.  I need to get it smogged but before that I need all the emissions crap and other things.  I am trying to find someone in Chico that can tackle it for me.  I think I could do it but I know it would be half assed and I want it done right.  I'm sure I will end up doing it, just need to find all the parts.
lilbuddy
so if i didnt make any plans tomorrow, you are coming over and were going to get the duals good to go.
GET IT!!!
kiyul4130
F' that snap ring man. well callen is pressing on the bearing to my gear today and i ordered up a new bearing from here so ill just give that one to you, so i dont have to pull off and put back on again. and your bearing is in good shape. i think i might be working on it tonight if you want to come by. im at work right now but ill give you a call when i get off. not sure if im gunna go out or not.
-kiyul-
ECV 7-11
KYOTA FOREVER
