Kiyul4130s rig
Started by kiyul4130, October 09, 2005, 09:09:33 PM
0 Members and 16 Guests are viewing this topic.
lilbuddy
That looks SICK bobbed. DO IT!
RIP Kyota.... you are the man
GET IT!!!
sloyota
BOB IT then build your bumper...I'm hopeing to fix my motor before the 23rd so me and Brian can come up to do some snow wheelin and snow drinkin with you guys,and visit with Cody,Jake,Kurtis and Larry while im in Chico.. :beerchug:
I'm not responsable for my own action's.
milla85
BOB IT! does anyone have some good links on how to "BOB"?
kiyul4130
Quote from: sloyota on December 12, 2006, 08:56:05 AM
sounds good. try and come up on the 27th as well for the lilbuddy's snow run, that is going to be awesome.
Quote from: milla85 on December 12, 2006, 07:52:14 PM
check out generalee7's truck on here. i dont have any saved but i bet if you went to yahoo and typed toyota bed bob you would get a million results.
-kiyul-
ECV 7-11
KYOTA FOREVER
Reynolds
About a third of the way down on page 2, I posted a buncha pictures of how I did mine. Pretty simple, cut (straight), grind paint down, weld back together. I had to do minimal metal massaging to get it to line up perfectly. Didn't use backing metal either. I highly recommend using a cut off wheel (if you are pretty accurate with them) to cut the bed up. I'm sure if I used a sawzall on it, I would be throwing tools for hours trying to get it to line up as good as I did. Good luck!
-Brian
Reynolds
-Brian
Ramrod
ive bobbed 3 or 4 beds and always use a cut off wheel on the outside for a super clean cut without waves and a sawzall on the bottom cuz its fast and easy over the ribs or the floor
boggerunner
i  prefer a gringer with a cut off disc, and a sawzall for the hard to reach places.  just need a good welder that u can turn down enough so u dont melt holes
kiyul4130
Hammer down time for Hammers!
alright boys and girls so in about 2 weeks or so im gunna really get my truck going for JV. i have a lot to do by then but none of it is really to hard. just time consuming and $$$$.
The plans are:
Clearance the bed
bed bob (mayyyybe)  ::)
rear bumper made with hoops to protect the bed
relocate my shocks / \ with single shackles
eliminate the blocks all together or cut them down to atleast an inch
turn my front marlin 4" pack into a hybrid pack, axles going ---------->
plate and move steering box forward as much as i can
brace the spring hangar
deff need  :turtle: DUAL ULTIMATE crawler! so thats gunna go in with the new clocked adapter.
gunna get a bud built skid but i have questions about that before i buy one.  :dunno:  :dunno:
an get drivelines worked on.
so i have a lot to do and cant wait to get started. ill post as i go.cya
-kiyul-
ECV 7-11
KYOTA FOREVER
Rockcrawlintoy
its never goin to happen lol
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
kiyul4130
Quote from: Rockcrawlintoy on February 20, 2007, 10:22:26 AM
Drew
shut up. your suppose to say sick!! ill help come down and work on it and pay for half of all your stuff!!!!!!!
-kiyul-
ECV 7-11
KYOTA FOREVER
Rockcrawlintoy
get  your :pokinit: by the end of next month and we can have a build party
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
kiyul4130
#132
nothing important. cleaning this stuff sucks. i got the crawl box all cleaned up. next is the entire other t-case which is gunna suck  :thumbdown:  im gunna try and get the box apart and the whole other tcase cleaned this week.
-kiyul-
ECV 7-11
KYOTA FOREVER
Ramrod
looks like fun!!, when I cleaned mine I sprayed them with engine cleaner a few times in a couple hour period and then took them to a car wash and pressure washed them and they came out perfect
topar
Whats that peeping tom dog of yours doing?  :hahaha:
kiyul4130
Quote from: topar on February 28, 2007, 10:35:19 PM
ya he likes to hang out on the hot tub.
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
screwin around on paint. not sure if i like it or not........        ?????
-kiyul-
ECV 7-11
KYOTA FOREVER
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Reynolds
I like it too, cut it up!  :biggthumpup:
-Brian
Yota4life
I like it 3 , bob it!
bmxanddie
wow, definantly bob it. back when i had truck instead of a 4runner i bobbed mine, and it came out awesome.  i say do it.
kiyul4130
so i emailed bud built a little over a week ago and i finally got a reply. my question was concerning a skid/crossmember for my duals. i have a 2" BL and was planning on getting the new clocked adapter plate from here which would give me a total of 3 and 3/16" of more clearance under my truck when i lift up the drive train. heres what he had to say and has anyone seen or is using this setup? :dunno:
""Yes, we have one that is designed for that situation! If you want a skidplate or not, we hae the right one.We make one taht is just a tube from framerail to framerail.  You can then add a flat belly skid to cover the whole thing. If you want a more noraml skid, we can do like our dual case skid, but with a clocked mount.  The tube version is $300, the skidplate version is $350.""
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
i also have a question about the tube setup? how would you run that. do you notch the tube and then run the tube on either end into the plate?? i think the skid would work better for protection. opinions please.
-kiyul-
ECV 7-11
KYOTA FOREVER
Duffil
looks like it just bolts up to the tcase and the frame.  I think it is a waste of clearance over the skid design,(tube is thicker than 3/8 plate) unless you put the tube above the tcase?
kiyul4130
i believe this is how its installed. you cut the tube and run it into the tcase mount. so the tube wouldnt be below the case. heres a weird drawing i did of an above view.
-kiyul-
ECV 7-11
KYOTA FOREVER
Duffil
that would make more sense than the picture you have up there.
Ramrod
you could just make one like mine?
kiyul4130
Quote from: TEAM RAMROD on March 05, 2007, 12:37:57 AM
ya i forgot about yours. do you think you post up a good pic whenever you get the chance of yours. i remember you briefly telling me how you know someone that makes the tcase plate for a $125 or something. id rather go that route if its possible. thanks
-kiyul-
ECV 7-11
KYOTA FOREVER
Quote from: kiyul4130 on March 05, 2007, 01:09:56 PM
my work makes that plate for $125 with the ends.  maybe a little less for just the plate.
