Good luck on sizing that with the glass on the sides.
that's what I was worried about but all you do is bob in the window opening... your window won't open as much... or at all if you bob that much... but it'll look still have the orignal look to it... Big blue have you thought about welding the top back together?
the metal is probably thinner than a beer cans metal so there is no chance of welding. I was also thinking of trying something with some sort of epoxy. The window won't be an issue cause I am going to bob it in the section where the rear window is and that window will just slide foward and should be perfect. If not I will just take them both out and put in a piece of plexiglass or cut the one piece a little
well I just pulled the side windows out and it turns out this thing is made of fiberglass. It is about 1/8" thick. I guess it just sounded like thin aluminum. I am going to start putting some lines on it and cutting in a little bit then I guess it is time to learn how to fiberglass. I will post up pics when I make some more progress.
Started by BoMXtreme Parts For Sale
Started by Ramrod Parts For Sale
Started by AaronB Parts For Sale
Started by MT yota Parts For Sale
