the hole point of a turbo is to force more air into the motor not air from the carb to the turbo that would make no sence a turbo sucks air in and spins in the turbo and multiplys the speed and the shots out thru the piping into the intercooler to cool the air because the colded the air the better and the shots into the intake of the motor but in doing that the motor will need more fuel and with all the air coming in it must go out so you will also need to upgrade your exhaust
carbs suck everywhere period.
if you want to get technical, it is not the carb that sucks, but the vacuum created by the downward force of the piston in the cylinder that in turn sucks air/fuel through the carb...
no, it chokes
Started by Jared Engine
Started by Remotruker Parts For Sale
Started by 1985ToyotaForLife Parts Wanted
Started by TURBO « 1 2 3 4 » Project Research and Build-Ups
Started by Skinny_Pedal Engine
