First Gen to Third Gen build, Updated!!
Started by WideOpen, September 15, 2005, 12:56:39 AM
TOYJOETA
Nice build up thread man, looks awsome, I love the way 3rd gens look with SAS.
WideOpen
Thanks toyjoeta  :beerchug:
Here is the rearend now,  I still need to get off my lazy ass and make bumpstops!
WideOpen
The next step was to install dual cases with stock gears in both. I wanted to keep the bench seat and still be able to slide it forward. That way my wife could reach the pedals if she wanted to do some wheelin. I modified the rear t-case lever to move it forward as far as possible, which was 5". I used some scrap rod that was laying around.
WideOpen
Here i cut out the floor board for clearance. Shifter is in 2WD-HIGH in this pic
WideOpen
4WD-HIGH
WideOpen
4WD-LOW, perfect fit, nice and tight. I'm not worried about it rubbing on the cab because of the Front Range Off Road crossmember (which is a very sweet product :thumbs: )
WideOpen
I formed this plate out of aluminum to make a tunnel for the shift rod. Made sure to make it all bolt on for easy removal.
WideOpen
All back together. It would almost look factory if i would of had a grey boot! The best part is i can slide the seat forward about 3"-4". Just enough for wifey to drive.  I'm not sure if thats a good thing tho :headscratch:
RHG
 :thumbs: Very clean job so far. I like how you have kept the truck in its good condition while at the same time doing the SAS and duals.
WideOpen
Thanks Rocks, its a daily driver and i think the cleaner it is the more reliable it will be. :yupyup:
I needed a front bumper for my winch but i didn't want to use the smitty off the old truck. So i chose marlins DOM front and rear bumpers.
The quality of the bumpers is awesome! Another sweet product from  :turtle: ! :thumbs:
WideOpen
Fresh off the brown truck!
WideOpen
#42
Choppin up the radiator support :_order: ( Those are some dang good scissors! :laugh: )
WideOpen
Test fitting. It almost fit perfect, i just had to do some grinding on the upper mounts
WideOpen
Time to shoot some paint. I used black MRO high solids paint in a rattle can ,very tough stuff
WideOpen
While i was painting, Uncle Oregon dropped off some liquid sunshine, just to brighten my day! :thumbsup:
WideOpen
#48
Better pic of the bumper, with a little ditch posing thrown in for good measure :gap:
WideOpen
Rear protected :biggthumpup:
4DEES
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
WideOpen
#52
Close up, I have since moved my plate up so the local bacon wont harass me as much :crossed:  :horseride:
WideOpen
#53
Thanks Yota, your toy is pretty sick too :beer:
I just really need to get this truck on the trails, SOON!! Been busy gettin my toy built and lately helping my friend get his runner trail worthy! It will be sweet when its done! I envy the room inside the runners!
This is his build  :yesnod:  http://board.marlincrawler.com/index.php?topic=14309.0
WideOpen
Got the bump stops in finally! I made them out if 2"x3/16" wall square tube with 2 1/2" X 1/4" laser cut plates for the bump pads. I set them up so the springs go flat. There is alot more up travel available but i would rather loose a little flex than damage the springs by going negative arch!
Front
WideOpen
Rear :qtip:
WideOpen
Also installed a cobra 19 DXIV CB so i can BS with my buddies on the trails!  It sure is lame that to get to the radio on a 3rd gen, the whole lower dash needs to come out!  :screwy:
bluetoy84
All I can say is  :bling:
Looking good  :clap2:  , can't wait to see some trail pics  :thumbs:
sloyota
really nice job.I need you to help with my SAS and rear end,I,m doing the same thing on my 88,man i wish you were in nor-cal.. :beerchug:
I'm not responsable for my own action's.
