Transfer case popping out of gear in 4-Lo
Started by waskillywabbit, August 27, 2005, 04:22:40 PM
waskillywabbit
Happened about half a dozen times or so and once on a hill...not fun.
Anyone know what the problem is and how to remedy it?  Or a place to look for help?
:yupyup:
Heavy duty detent spring will solve the issue.  I had that problem with mine awhile back.  The HD kit from Marlins cured it.
Willy Mammoth
Also, what gear set are you running? Some of the early low gear sets had problems with this. The answer was they didn't have a backwards taper where the sliders locked onto them so they would slip out of gear. There is a writeup on this in the Marlin comparo thread that Big Mike did  a while back.
Marlin
Also check for floor boot bind.
We have had a lot of problems with the handle being in a bind when shifted into low range.
Check for broken motor mounts, loose bellhousing bolts, rusted or frozen rear driveline slip yoke.......
Willy Mammoth
Welp, there you have it folks, The man him self has spoken and I must say he really knows his stuff. Can't wait to shake your hand, maybe some will rub off.  :ha_ha:
