Author Topic: How to weld the front spider gears together?!!?  (Read 7669 times)
Crawling82toyota
  • Turtle Points: -1
  • Member since Aug '05
« on: Aug 25, 2005, 10:39:02 AM »
alright.. i am looking to weld up my front spider gears on my 82 toyota so i can lock up my front end....first off..i know that a lot of people dont recomend that...but im not worried about it...i am putting new gears in in about amonth anyways..and i just want to lock up my front for a couple wheelin trips without spending the $$$....so i took apart the whole front end...pulled out my third memeber..and have the chunk laying on the ground.....i am unsure how to weld the spider gears and where to weld.....if anyone can help me out i would really appreciate it...
89 toy
  • Turtle Points: -1198
  • Male Posts: 383
  • Member since Dec '03
weld the spider gears to the side gears and weld the side gears to the carrier.
k20
  • Male Posts: 55
  • Member since Jul '05
once youve welded the sun gears and side gears together and to the carrier i always put some steel flatbar between the gears and then run some more weld around it all.i wouldnt recomend having the front permantly locked though,i did mine and on full lock it stilol went straight ahead,until i gave it some throttle.
mr4x42u
  • Turtle Points: 700
  • Member since Sep '02
  • LOCKED AND LOADED
welded fronts suck,,and will help aide in busted birfs,,but just like the pic and the threas says,,,weld all spiders together,,and to the carrier...Make sure it is free of oil and really clean to get good welds..also make sure you clean the berries out after welding it..I used the anti dingle berry spray with good results..don't rember the name of it,,but its sold at some napa and most welding stores..
flourman
  • Turtle Points: 220
  • Male Posts: 333
  • Got Body Damage??
This might help you although it's a Ford 8.8.
Doin' it FULLSIZE style!
fellowsped
  • Male Posts: 23
  • Member since Jun '05
  • sh*t or get off the pot
use a torch to heat up the carrier when you go to weld the gears to it. it makes for much easier welding.
remember no matter how bad life gets there's always beer.
money is for rich people
85 toyota p/u, lincoln locker rear, debating on lincoln locker front, 22r desmoged, 31 bfg a/t (worn out but came with truck), the plan; 35 super swamper boggers, duel t-cases, buggy leafs, crossover steering, internal roolcage, rocker bars, a winch, and a few other little things.
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
  • Member since Feb '05
This is my front third welded up.
alwayzbroken
  • Male Posts: 1,905
One more
SLOYOTA808
  • Turtle Points: -21
  • Member since Mar '05
    • Damn Kid Off Road
Somebody says that welded front diffs are not the reason he has gone through 9 birfis...
alwayzbroken
  • Male Posts: 1,905
Not arguing, but what is the difference between a Detroit locker in the front and a welded diff in front as far as stress goes? Obviously the locker unlocks when turning but these situations are usually not under load anyway. When the locker locks and unlocks under load doesn't that multiply stress? What are you supposed to run in the front? :confused:
SLOYOTA808
    • Damn Kid Off Road
A locker has a little bit of 'give'; welded diffs have no 'give'.
ARB air lockers is the best (and most costly) solution. :ack:
bluetoy84
  • Turtle Points: -100
  • Male Posts: 300
  • Member since Jun '04
  • rice bouncer
If you have an ARB locked ,  it is no different than a welded diff . Either one is gonna be hard to turn , you just have the option of unlocking an ARB. I am not a fan of selectable lockers for front use. I don't want to have to un-lock the front end every time I need to make a tight turn or have to lock the front end "when you need it". Everyone I know with an ARB is constantly flipping switches.
Go with a detroit and just wheel the piss out of it. It will release when you turn and lock when your going forward , no need for all that switch flipping. :headshake:   Just my  :twocents:
Last post May 11, 2006, 08:30:33 AM
by yotadork83
Last post Feb 09, 2009, 11:43:49 PM
by Loosekannon
Last post May 15, 2009, 01:06:38 PM
by Duffil
Last post Apr 13, 2010, 09:45:33 AM
by -Jake-
Last post Jun 13, 2011, 05:25:53 PM
by yota_krawler
